Home > Puma (Tdci) > looking at the 2012 2.2 110SW
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
looking to acquire this, want a few few quick questions.
its fitted with a particle filter, does river crossing and getting wet do any damage to the particle filter?
how sensitive is the engine to poor quality fuel? my current ride can drive on vegetable oil, so i never have issue with fuel. but am not sure about the commonrail euro 5
Post #152458 28th Jun 2012 2:52pm
farmer giles
i assume the wading depth is 500mm like all other defenders unless you fit specific wading equipment.
i can't help with your fuel question though; perhaps an email direct to LR may assist?
Post #152666 29th Jun 2012 8:33am
ronwong
thanks for the reply.
Post #152709 29th Jun 2012 11:58am
Re: looking at the 2012 2.2 110SW
I think it's fair to say that it will be more sensitive to poor fuel that previous Land Rover engines. In some markets (South Africa for instance) they are being supplied without the DPF because they won't work with the local fuel, which has a much higher sulphur content that Europe. I don't know what veg oil would do to it, but I'd bet good money that it would invalidate the warranty. Darren
Post #152717 29th Jun 2012 12:16pm
ronwong
the dpf isnt it in the exhaust, when the fuel is poor, wont it cause problem further up like uel lines, pump, injector, choke the filter or stuff?
i am currently driving a 96 benz indirect injerion 2.9 it can run on anything.
Post #152729 29th Jun 2012 2:33pm
mobilecentre
The 2.2 as most other modern diesel engines will not run on veg oil without damage.
Post #152732 29th Jun 2012 2:55pm
ronwong
wont be trying vegetale oil, but some parts of malaysia has poor fuel so i wonder ifmi should load 2 jerrycans of good quality fuel when going to such areas
Post #152747 29th Jun 2012 4:03pm
