Its attached to the cat/exhaust downpipe from the turbo, its not easy to get to from underneath, but it is easier...
A cat replacemant downpipe (avoid Terrafirma ) from a good supplier, (I put a Twisted one on a Puma), comes with a bracket to attach the heat shield, then all rattles can be solved.
If the shield has 'torn' from where it's bolted on, a larger penny washer usually suffices if you don't want to replace the cat.
25th Jun 2012 6:06pm |
