Home > Td5 > clutch failure
shazzy90
clutch failure
hi the clutch on my 110dc gave up today ,not being able to press down,no fluid running down pedal,so i guess it is the clutch which has gone and not the cylinder ,any recomendation as to what type of clutch to replace with ,and best place to buy for best price,do you do the duel mass fly wheel ,while the box is out even if it is not damaged?any advice please
Post #151628 24th Jun 2012 2:48pm
wslr
Could be something else but that leaves the slave cylinder or an issue with the fork. The fork has a plastic insert which can wear out, or excessive contamination of the DMF and clutch plate, but pretty much always it is a clutch issue.o
I'd give Andrew a call at Defenderbits (support the site sponsors). The AP or Valeo kits are OK, but see what Andrew suggests as I know he has an eye for bits that work. You will need to inspect the DMF once you have removed the T-Box/G-Box and the clutch bits. If it has been excessively contaminated or there is too much play in the unit when you try and move it around (in situ) then one of the Valeo DMF's are fine. Get new Genuine bolts or make sure you Loctite the old ones back in.
There is a section in TOPIx about the DMF and how to check it is OK. Sometimes it is obviously bad, but not always.
Post #151629 24th Jun 2012 2:58pm
Defender SVX
United Kingdom 2008 Defender 90 Puma 2.4 SVX Soft Top Santorini Black
Re: clutch failure
Bring it down here I'll sort it mates rates/forum discount? Pm me if interested Formerly mao99999
16 Focus RS Nitrous Blue.
11 FFRR TDV8 Vouge SE Black Black.
08 DEFENDER SVX SOFT TOP (SUPERB)
08 DEFENDER 110 DCPU Stornoway grey (Overland Exploration Unit)
05 Fiesta ST 150 Van
04 Jaguar XKR 4.2 Supercharged V8
02 DEFENDER 90 TD5 (next years soft top project)
95 DEFENDER 110 CSW 300 TDi Phoenix black
95 DEFENDER 90 HT Monti Carlo blue COUNTY 300 TDi
67 109" SERIES 2a TUNED 200 TDI
64 DAVID BROWN 990 rat look
55 86" SERIES 1
Post #151630 24th Jun 2012 3:02pm
shazzy90
hi all 110 now back up and running ,the clutch or the fly wheel did not fail,it was the bearing that failed andd melted,thrust i think,so as it was stipped down i changrd the lot do i now have a spare fly wheel and clutch if anyone needs these parts pm me
Post #152820 29th Jun 2012 10:51pm
