![]() | Home > Maintenance & Modifications > Alpine amp model number ? |
Simon,
I can do better than just the number.... ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
![]() Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
Simon,
Just an afterthought...If you're not hooking up to an Alpine head unit you'll have to reconfigure the connectors as I did because Alpine use their own unique type. ![]() Treat every day as if it is your last....one day you will be right!! |
ay4alex Member Since: 18 Feb 2009 Location: Midlands Posts: 328 ![]() ![]() ![]() |
Does this make much of a difference to sound quality / volume K9?
Alex 110 Tdci Double Cab |
Yes adding to my Parrot Asteriod should fit behind it. Simon 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
Alex, yes it does. I also added a sub as well.....
![]() Simon, I've slipped mine behind the Parrot Asteroid too. I tywrapped the amp to the original 'locating lug plate' where the original head unit located into. As the Asteroid is less than half the depth of the original unit it fits in nicely. The amp is then easily accessed if you have to get to it. http://www.defender2.net/forum/topic7481.h...t+asteroid If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
