![]() | Home > Maintenance & Modifications > Help regarding props |
steveandlooby Member Since: 08 Nov 2009 Location: Bedfordshire Posts: 35 ![]() ![]() ![]() |
Help folks!
I know nothing regarding vehicular engineering but as I have a big (big) trip planned for next year I need to dive under/into our Puma 110 and become.........intimate (perhaps we shouldn't have called him Leonard??) I have to replace a diff pinion seal. Whilst researching this I have come across threads regarding replacing prop shafts on vehicles that have had a 2" lift with a wide angle prop. Our vehicle has such a lift but which replacement to go for. I have never been one for skimping - rather buy quality and only buy once! But what to go for? http://www.extreme4x4.co.uk/acatalog/32_WI...HAFTS.html Or http://www.rimmerbros.co.uk/Item--i-FRC8390BP-WA Or What? And....is it as simple as taking one off and putting the new on and....do you replace both props. Be gentle. Steve |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2963 ![]() ![]() |
you have PM
Give Gwyn lewis a bell he is about the best out there to advise
![]() http://www.gwynlewis4x4.co.uk/page36.html NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY |
I changed both of my props on my 90 for HD/DC units
KEY KEY THING TO REMEMBER IS The rear prop makes your handbrake work ... so 1. have your truck on a level surface 2. chock the wheels 3. put in diff lock 4. always use new nuts and bolts also, there is a special tool you can buy that will save you loads of time |
Thanks for replies one and all.
I have spoken to Gwyn Lewis and he doesn't think I need to worry about changing prop as the supplied one is more than adequate. Nice bloke. Zagato the plan is to drive to Vladivostock via the Stans and Mongolia then ship to Oz for 6mths!! |
