Home > Maintenance & Modifications > air horns |
jonny1966 Member Since: 29 May 2011 Location: kent Posts: 87 |
the child in me wants a truck air horn on my puma
any one know where the best place to get a set from ?? |
4th Jun 2012 10:31pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10382 |
Hornblasters !!
http://www.hornblasters.com/ Go on the gallery and watch the terror on the streets videos....brilliant |
5th Jun 2012 8:15am |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
Nautilus air horns are as good , but a lot easier to fit. A number of people on D3 site are fitting these in replacement for standard horns, though wiring should be checked to make sure it is correct.
I had one fitted to my old 101 and 110. http://www.amazon.co.uk/s/?ie=UTF8&key...mt7j05jb_b I also have a large air horn trumpet. T rig this means the need for installation of a compressor and tank. Great if you want to inflate tyres etc, but a lot of hassle just to occasionally only blow a horn. |
5th Jun 2012 8:43am |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
This has been done several times before:
http://www.defender2.net/forum/topic11728.html?highlight=horn http://www.defender2.net/forum/topic12077.html?highlight=horn Steve. Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
5th Jun 2012 9:04am |
thanks guys
all very helfull |
5th Jun 2012 10:49am |
AlpenAndes Member Since: 20 May 2011 Location: Currently Chile Posts: 128 |
I just installed that Wolo road warrior 845. Found one for 50USD.
http://www.wolo-mfg.com/truck.htm http://www.ebay.com/itm/Wolo-845-Road-Warr...mp;vxp=mtr Sounds great, but I underestimated the space available under the hood to fit a lenght of 55cm and 16cm diameter. Now it is behind the steering guard. |
5th Jun 2012 3:40pm |
did you need an air tank and compressor kit with it? have been looking at the chief horn works out at about £185 with the compressor kit plus postage |
5th Jun 2012 4:32pm |
Lukey Boy Member Since: 10 Jun 2011 Location: Norwich Posts: 122 |
Brilliant, I can just imagine the fun I'd have in Norwich (Prince of Wales Rd - Nightclubs) at 2 am on a Saturday/Sunday morning! 2008 110 XS CSW Stornoway Grey |
5th Jun 2012 5:27pm |
Sounds like Glyn's got the horn! :whistle: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2008 110 XS CSW Stornoway Grey |
5th Jun 2012 9:06pm |
That one, like some others as well, comes with a direct drive compressor, size like a fist, that was the easy thing to fit next to or rather together with one of the radiator fixings. Just for the horn itself I had to prepare a simple bracket using existing holes in the frame as I did not want to mount the thing visible. |
5th Jun 2012 9:38pm |
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 |
As Puma horns are also the anti-theft alarm, the appeal is greater than just noise making for its own sake. Unless accidental triggering of course. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
9th Jun 2012 10:01am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20376 |
Very true. Especially if the system is a bit more unique that way you will no that it is YOUR Defender and not another vehicle $W33T $0U7H3RN $UG4R 🇬🇧ðŸ´ó §ó ¢ó ¥ó ®ó §ó ¿ðŸ´ó §ó ¢ó ·ó ¬ó ³ó ¿ðŸ´ó §ó ¢ó ³ó £ó ´ó ¿ðŸ‡®ðŸ‡ªðŸ‡ºðŸ‡¸â›½ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
9th Jun 2012 10:11am |
I think low frequency & high decibels are the answer. Attracts attention & stuns any theif more than the high pitched shreiks & tweets most ignored alarms have. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender
9th Jun 2012 10:42am |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 |
Yup I've had two of these now, one on my old MG ZS and the other on the last 90. Both times it was just a case of swapping the spade connectors over to the new horn. The hardest part on both was getting to the horn in the first place |
9th Jun 2012 7:18pm |
