Home > Puma (Tdci) > How much harm with not approved oil – transfer case
rasmussen
France
I am in a situation where I cannot get the correct oil but I have to do a bit of driving for a couple of days before I get the correct oil.
Background:
The seal was gone, changed the seal at home, now lack of oil in box – waiting to get the correct oil delivered. But need to on the road now. Can get the other oil around the corner.
I can get something with the following spec:
Huile pour transmission mécanique (Mechanical transmission oil)
Performances exceptionnelle (exceptional performance)
Larges plages de températures d'utilisation (Wide temperature ranges of Use)
Viscosité 75w90, API GL5
What can go wrong if I use this oil for a week or so?
Thank you very much in anticipation
Post #149163 8th Jun 2012 11:36am
Naks
Re: How much harm with not approved oil – transfer case
Shouldn't be a problem if it's only for a week, obviously change to the correct spec as soon as possible. --
Post #149166 8th Jun 2012 11:49am
tatra805
Slovakia 2008 Defender 110 Puma 2.4 CSW Bonatti Grey
Moment
isn't it so the transfer case takes GL5 75w90 as standard?
The MT82 main gearbox takes GL4
as far as i know the GL5 is newer/higher standard and approved for hypoid gears while the GL4 is not.
See no harm in using GL5 where GL4 is the minimum standard, opposite can be a problem if hypoid gears are used (both being 75w90 of course)
correct me if i'm wrong please
Smile
Post #149184 8th Jun 2012 2:44pm
rasmussen
France
From MartinK post: “ Engine, Gearbox & Transfer Box Oil Change”
Transfer Box
"Refill to the level plug (2.4 litres). I used Fuchs Titan Race SYN 5 75W-90 Fully Synthetic Gear Oil (was Silkolene SYN 5 75w-90) - this one's GL5. "
I understood that as the requirement – but maybe I am wrong?
Post #149189 8th Jun 2012 3:19pm
MartinK
Transfer Box
Yes - that's correct. Gearbox is GL-4, but the transfer box is GL-5. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #149197 8th Jun 2012 4:32pm
yobbie
United Kingdom 1999 Defender 90 Td5 Heritage LE Bronze Green
Apparently GL5 spec oil affects bronze parts in gearboxes but I'm sure a few days would be fine
Post #149204 8th Jun 2012 5:12pm
MK
TF needs GL-5. It can also use GL-4. Puma 110" SW
Post #149258 8th Jun 2012 8:35pm
