Home > Maintenance & Modifications > grease nipple knocked off |
Grouse Member Since: 16 Apr 2012 Location: on the hill Posts: 523 |
they usually screw in and screw out. To get the broken bit out tap the pointy end / tang of a file into the hole and screw it out.
6th Jun 2012 7:41pm |
cheers Grouse, its just so wet here at the moment, I'll take a look tomorrow, I guess the land rover garage would be able to sell me a few spares ?
6th Jun 2012 7:53pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6112 |
Would be cheaper to go to an autofactor place,
edit: Just checked microcat, a standard prop nipple is part # TYL100030 and £1.78 It also shows 234532 @ 52p as well, for the same one (ahh.... the above one is for the main splines, the other os for the UJ itself, so i'd go for the 234532 one) |
6th Jun 2012 8:12pm |
bpman, it might be easier than a visit to a main agent, but I bought a handful from my local Agricultural Engineers, he had an assorted box with different threads and various cranked heads, they cost pennies.
6th Jun 2012 8:37pm |
boxer Member Since: 12 Jun 2011 Location: north yorkshire Posts: 48 |
hi bp man if i was you get a set of easy outs, not expensive but are excellent for removing broken stubs etc the problem with using a file is it can spread the nipple if you tap it in to hard.
6th Jun 2012 8:50pm |
Hi Bpman,
Got everything you need in my garage if you fancy a trip down again! You'll need to bring your own nipples! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th Jun 2012 8:45am |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
I hope you are going to grease them for him as well If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
7th Jun 2012 8:54am |
Nutella works for me!!!
Noworries...any news on you revisiting Green Island? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
7th Jun 2012 9:27am |
thanks all, I'll pick some up later today and let you all know how it goes.
Mal - thanks for the kind offer |
7th Jun 2012 10:14am |
You're welcome Steve! Do you want me to chill the Nutella? If you go through life with your head in the sand....all people will see is an ar5e!!
7th Jun 2012 10:44am |
