![]() | Home > Maintenance & Modifications > WHEEL ARCH EXTENSIONS |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
TC Member Since: 21 Nov 2010 Location: Gloucestershire Posts: 715 ![]() ![]() |
give them a ring ![]() |
Morning
![]() Just got some of these (the ST Maxx sidewalls throw everything up over the sides). Yours look ace. I wonder if you could help with a couple of things? 1) Looks as though you drilled through the edge of the eyebrow at an angle - looks difficult - any tricks needed to get them in the right place ![]() 2) What did you use to cut them with? They're bloody tough and I don't want to chew them up with a saw etc. ![]() 3) Any chance of a side picture fitted to see what shape you cut them? I have no artistic ability whatsoever ![]() Cheers, Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Hi Matt, I took the eyebrow off the truck and just took my time drilling them..... just start at one end and take your time mate there isn't much to play with...put the extension against the eyebrow and drill your first hole then put your first self tapper in to hold it together.....it would be best if you could get someone to help hold it as tight against the eyebrow as possible then drill the holes as you go.... i also cut off the excess rubber before i drilled them so i could se better where i was drilling......
To cut them... i put them on the eyebrow first..... put them on a flat service and got a straight edge and just use a Stanley knife to cut on what ever angle you need.....the Stanley may not cut straight through the first time but it will give you your mark.....then just bend the rubber over and trim off the rest ![]() The shape i cut ...I just measured them all from the edge of the eyebrow I think it was 2" up from the bottom and just a straight cut ![]() ![]() Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Brilliant - many thanks
![]() I wondered if you trimmed the excess around the edges - wasn't sure if we had the same extensions... Looks like a good project for a (this?) wet weekend ![]() Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
No problem put up some pics when you Finnish
BigWheels Member Since: 21 Mar 2010 Location: Somerset Posts: 1405 ![]() ![]() ![]() |
I suppose, literally, the other side to what you did, would be to put a spacer between the factory arch & panel.
At least then no holes would have to be drilled in the colour matched arches. Land Rover Defenders. 67 years heritage, minimal appearance changes, still going strong all over the world. Not a fashion vehicle, but fashionable to own. Made for the needy, not the greedy. Ta ta Defender |
Exactly
![]() In my case, I fitted one flexi extension and it didn't look right (my fault, I'm sure). I ended up buying 4 OEM black arches from the UK (£150)and just sold the blue ones for £90. Would have got more if one of them didn't have holes in it ![]() Very happy with the look of them and Peter at Nakatanenga assured me that another TÜV testing station would pass the wheels/tyres (unlike the w*nkers nearest here). I looked for "professionally" made spacers everywhere but came up blank (I'm sure I saw them somewhere). If I could find them I would still fit them ![]() But shout it at them in German because life is also terrifying and confusing... |
That's what one of the guys from Russia as done 3WHouse ![]() ![]() Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Bloody hell - that's some serious plate on the front
![]() ![]() But shout it at them in German because life is also terrifying and confusing... |
He told me its so the lights don't smash when he go's through icy water
df1 Member Since: 06 Aug 2011 Location: Ireland Posts: 221 ![]() |
What's the story with the wheels, looks like a solid flat dish and can't make out the wheel nuts
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20749 ![]() ![]() |
Probably a cover type thing to stop things sticking in the spokes off road. (I would have though) WeWillWin🇬🇧🇺🇸
⛽ï¸ðŸ›¢ï¸âš™ï¸ðŸ§°ðŸ’ª |
