![]() | Home > Maintenance & Modifications > How do you replace a chassis? |
Just wondering what work is involved, e.g. how much must be dismantled first and how long the whole thing takes.
Cheers Matt Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 330 ![]() ![]() ![]() |
Depends on how many hours in a day you are prepared to spend and how good your working environment is.
I managed to swap the chassis on my old 110 in just under two weeks on my drive, but could have done it quicker with better facilities/more help. For a 110 hard top I removed and refitted the roof and sides as one unit, rear body tub as another (hint: four large strong friends are VERY useful at this point), bulkhead with all parts attached except windscreen frame. Order of work was something like: interior trim, doors, bonnet, wings, radiator, roof & sides, body tub, seat box, bulkhead, fuel tank, engine & transmission, lift chassis off axles and suspension and then in best Haynes fashion, reassemble in the reverse order replacing parts as necessary. Getting panels to fit correctly can be fun ![]() A good engine crane is essential. Anything I've missed I'm sure others will fill in the gaps... |
Thanks for all the info guys - I know it's thinking way ahead but I like to be prepared
![]() I have a beetle with a galvanised floorpan and I reckon it will last forever ![]() But shout it at them in German because life is also terrifying and confusing... |
My chassis replacement has been goin on since October (admittedly I haven't given it as much time as I should have done) but its finally finished and gone to the paint shop!
It all depends on how much time and equipment you have! |
