Home > Technical > Can you use Fellows Shredder oil to lubricate bolts? |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
I see no reason why not. However, why whould you need to unless they were very corroded? Towbar bolts are usually 8.8 grade M16s and need tightening to something like 200NM, so just wind them up!
Pete |
30th May 2012 9:35pm |
kmac Member Since: 07 Oct 2009 Location: Middlesex Posts: 1309 |
Yeah went with dry in the end - wound up to 215 Nm They are 8.8 grade M16s |
30th May 2012 11:26pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17527 |
Most published torque figures are for clean unlubricated fasteners (unless specifically stated otherwise).
31st May 2012 11:29am |
