Home > Td5 > Heated screen connection
landy andy
Does anybody know if the wiring is in place for the heated screen?
I can't tell by looking at mine as I have heated screen fitted, but a good mate of mine wants to upgrade. His is a 04 Td5 hardtop, like mine, I have managed to sort him windscreen foc Whistle , but now have to sort his wiring Big Cry
Thanks
Andy
Post #147661 30th May 2012 9:50am
Not unless the vehicle left the factory with a heated screen fitted.
Post #147663 30th May 2012 10:03am
landy andy
No, not standard fit on the hardtop, so will have to wire from scratch then Big Cry Big Cry
Andy
Post #147677 30th May 2012 11:57am
bmc054
2002 Defender 90 Td5 HT Tonga Green
Wiring
HI
I bought a wiring kit for the job all relays timers cables included ready to fit from mobilecentre who are now sponsors on here,the chap was really helpful too Thumbs Up
Post #147679 30th May 2012 12:01pm
landy andy
Re: Wiring
bmc054 wrote:
HI
Ohhhhh, like the sound of this. Can I ask rough cost?
Will save messing about Thumbs Up
Andy
Post #147736 30th May 2012 3:51pm
mobilecentre
Here is a "generic" kit including the OE switch
http://www.mobilecentre.co.uk/land-rover-d...p-694.html
This is fused at 30A (350W) and is a single feed for the screen which will suit OE Pilkington screens.
Some aftermarket screens require a dual input which can be supplied as well.
We can also supply with a Carling switch or just the timer relay and you build your own
Post #147739 30th May 2012 3:57pm
landy andy
Thanks for that Thumbs Up Thumbs Up
Looks like that's the easy option
I assume it's just plug and play?
Andy
Post #147780 30th May 2012 7:45pm
mobilecentre
Connections have to made that are not plug in such as power from the battery and illumination pick up from a nearby switch.
It is as close to factory as you can get in a pre assembled kit form.
Post #147823 30th May 2012 10:15pm
