![]() | Home > Wheels & Tyres > Wheel and tyre help please |
Yes you can but no you Should not is the answer
Reason plenty have fitted 285's to a 7J rim but you should be aware is the fact in the eyes of most 7J is to narrow and quite a few tyre places will not fit a 285 to a 7J rim |
WelshDefender Member Since: 02 Dec 2011 Location: Gwent Posts: 62 ![]() ![]() |
What potential issues could this cause (sorry for the noob questions!!)
I think it varies between different manufactures but for an example if you go to BFG.com (not uk) site they say the narrowest wheel that 285’s can be fitted to is 7.5inch. As it has been said there are plenty of folk here who run 285’s on 7 inch rim and it really comes down to an individual choice. For my part if something was to go wrong it will always happen to me so I use 8.5 inch wheels to be on the safe side.
Projectblue Member Since: 22 Nov 2011 Location: Devon Posts: 1096 ![]() ![]() |
16x7 means 16" diameter and 7" width. This means a 285/75 would be a tight squeeze on the 7J rim and the bead may burst off in excessive circumstances such as heavy load & compression over rocks/ off tarmac. I'd have no issues with a 285/75 on a 7.5J rim, but I think 7J might be pushing, especially if you do off road or run with a load. My thought would be get some gen LR 7.5J alloys and sell your aftermarket ones. |
'ET' is the offset - below is from a Google search:
Offset Alloy Wheel Offset (ET) Explained: This is important if you are thinking of purchasing aftermarket alloy wheels. The offset is the distance in mm between the centre line of the wheel rim, and the line through the fixing (hub) face. You can have positive (+), negative (-) or neither (0). The first important reason offset is so important is that it is ultimately responsible for the position of the wheel under the wheel arch. Get it wrong and your wheels can scrub against the bodywork, suspension or at worst not turn at all! Secondly it determines how the suspension and self-centering steering behave. The most obvious problem that will occur if you get it wrong is that the steering will either become so heavy that you can't turn the steering wheel, or so light that you need to spend all your time keeping it in a straight line. Example: A Citroen Saxo and a Ford Fiesta have the same stud pattern, so in theory a Fiesta wheel will fit a Saxo wheel and vice versa right? Wrong. Although both cars have a positive offset the Saxo’s is very low at around ET15 and the Fiesta’s is higher at around ET38. This means that the hub mounting face on the Saxo’s wheel is closer to the centerline of the wheel and the Fiesta’s is closer to the outside of the wheel (roadside). In a nutshell you need an offset as close to the vehicles original wheel offset as possible. |
Thanks all. Will either stick with 265's or get a set of modulars instead. Not keen on alloys anyway as I do a lot of greenlaning and they are getting a bit scratched up, but thought I could save some cash if I kept them.
Will get some mods and sell the alloys Cheers Adam |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 ![]() ![]() ![]() |
I've run 295 and 305 on 7 inch rims with no problems and used them on road off road no issues whatsoever ever
![]() Steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
