Home > Maintenance & Modifications > Fitting 1/2 height dog guard (SP Landrovers)
ZeDefender
Here's my dog guard post, as threatened Laughing
I wanted a top-half-only dog guard for my 110SW so I could load underneath and so rear passengers can escape in an emergency Wink Trouble is the cheaper ones for a 110SW are full height and the 1/2 height others are designed to be mounted to a bulkhead... so I had to play a bit Very Happy
I only used the brackets provided with the guard Thumbs Up
Here's the finished product, £50 from SP Landrovers Thumbs Up
So, first I rounded off the lower mounting points... after discovering the sharp edges carve up the interior trim Evil or Very Mad :
Then I cut off part of the bulkhead bracket for mounting on the side trim then bent it and drilled and tapped for M8 (the size of the wheel-screw threads:
Drilled the trim for M6 rivnuts with washers on the other side for grip. Needed to remove two trim fixings to do this - used the right tool - the fixings are about 2" long and tight as hell!
My beloved rivnut tool and beloved butyl to get the washer to stick underneath Thumbs Up
Fitted bracket:
Fitted guard held against the grab handles (see top photo):
Loading space:
The brackets look a little "home-made" but, I think, perfectly acceptable. Decided not to drill into the roof - I'm using a less "invasive" method to secure to the grab handles (see top photo)
At least the dog likes it Smile
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Tell someone you love them today because life is short.
Post #147060 25th May 2012 3:46pm
xatzhs
Nice work! To be fair the dog looks like a real killer - can see why you needed to separate it from humans Laughing
Post #147083 25th May 2012 5:17pm
ZeDefender
Next: How to stop your windows falling down
p.s. don't let her innocent (stoned) looks deceive you - she nearly broke someone's hip the other day, falling over her Laughing
p.p.s. In Germany, it's a legal requirement to have a dog in a harness or behind a dog guard... or a 60 Euro fine :shock:
Post #147091 25th May 2012 6:24pm
