Home > Maintenance & Modifications > Replacing Steering Wheel With Snap-Off Version |
affiliate13 Member Since: 29 Jan 2012 Location: Belfast Posts: 82 |
Since you guys have helped me out so nicely with everything else so far i thought i would impose upon you all once again for a little more advice.
I found this: http://www.demon-tweeks.co.uk/performance/...ring-wheel and http://www.demon-tweeks.co.uk/performance/...el-adaptor I wondered would i need much else to make this switch work, i have the factory fitted wheel in the cab that looks like it has an air bag in it, i know there are two spline versions, i am not sure about MY2012 vehicles? Is the steering wheel something i could do with basic tools? I have a set of seat risers and a bulk head removal bar to fit too, i just need a little more space and i think it will be more than comfortable. This flat bottom wheel should give the last bit needed. Last edited by affiliate13 on 20th May 2012 4:20pm. Edited 1 time in total |
20th May 2012 10:16am |
Yes,
I think i saw that really thin one on ebay. It looked fine, i just wasnt sure about tooling and alignment after i get the old one off. Type of thing i would imagine it is important to get right first time n all. Pity those B&G ones are no good, they looked well enough made, thanks to the tip, another bullet dodged. |
20th May 2012 3:19pm |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
yer they are really well made mate cant fault that aligning it is easy its getting the steering wheel straight which is the
20th May 2012 3:36pm |
