Home > Puma (Tdci) > exhaust gasket |
bob neville Member Since: 30 Apr 2009 Location: Marbella Posts: 3248 |
No gaskets on my 2009 110 centre section when I removed it.
Bob 2015 Jaguar XE240 R Sport - goes like ....... !! 2013 Defender 90 CSW - sold 2009 Defender 110 Double Cab - sold 2001 TD5 90 CSW - offroad project - sold to a forum member 2011 Porsche Boxster - for the sunny days ! |
19th May 2012 7:34pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2431 |
I just did mine today. NO gaskets needed. However, I fit one at the turbo end. Puma 110" SW
19th May 2012 7:50pm |
chopperpk Member Since: 14 May 2012 Location: sunderland Posts: 32 |
Thanks for that.does it make eney difference just takeing the center box out. cycle
20th May 2012 7:25am |
20th May 2012 7:35am |
Sound wise no but the engine does seem to rev a little better.
20th May 2012 7:51am |
Well i will give it a go.and i will put stainles bolts on cycle
20th May 2012 7:59am |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
oooh no not stainless on a exhaust they get hot and then they biond up horrible
if you do use stainless put plenty of copper slip on them the same with using mild steel ones regards steve 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
20th May 2012 1:08pm |
Would u put normal bolts on cycle
20th May 2012 1:16pm |
yes personaly just put new ones in and give them a coat of copper slip
20th May 2012 1:23pm |
Yer i will probly will thanks cycle
20th May 2012 1:26pm |
I used stainles steel bolts, copper and shim nuts Puma 110" SW
20th May 2012 1:54pm |
Or write i dont now every body is differnt then.but i will copper slip them cycle
20th May 2012 2:16pm |
