Home > Td5 > Pressure regulator noise
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Hi guys there's a funny hissing noise coming from where the pressure regulator is
Could this need replacing ?
Any help appreciated steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #145359 16th May 2012 5:00pm
changill
United Kingdom 2003 Defender 90 Td5 HT Bonatti Grey
Never heard of an fpr hissing. Do you have an associated. Leak?
Is the hissing from the fpr or could it be from the exhaust manifold? Only Alcohol Can Save me Now
Nanocom Available in the North West
Post #146053 20th May 2012 9:02am
wslr
I wonder if it is just air in the fuel being circulated around the head area? Confused
Post #146059 20th May 2012 9:26am
big steve
honestly it sounds like a air leak and thats without the engine running
yes the exhaust manifold is blowing but as said the engine is not running when you can hear the noise
is it common for the manifold studs to snap without it being tuned as the very front 2 were allready sheared off and the manifold was out by about 5 mm
Post #146087 20th May 2012 1:06pm
wslr
I still think it is the sound of air in the fuel running around the FPR/Head/Cooler...
Take a closer look by running a purge cycle by pressing the throttle down 5 times with ignition on. Then try to track it down more closely.
The fuel pressure is (or should be) at 4 bar so if there was a leak of any type, it would involve diesel leaking.
Post #146143 20th May 2012 6:55pm
