Home > For Sale & Wanted > REVERSING SENSORS FOR THE TDCi
Page 2 of 2 <12
dgardel
Italy
d j hutton wrote:
Here's the thread for the Dolphin ones, look pretty neat and have some recommendations as well.
http://www.defender2.net/forum/topic4457.html?highlight=sensors
DJ
Thank you DJ, great Alantd
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #143907 8th May 2012 7:13am
Gil9713
Sensors fitted without drilling holes
I decided to use two of the multitude of holes in the bumper rather than drill fresh ones as per dgardel.
Here's my result £29.95 later and 30 minutes to fit.
I placed the buzzer up high on the nearside interior and placed the control box behind the panel for the nearside light cluster........perfect and good coverage. Thumbs Up
http://www.parkingsensors.co.uk/adhesive_p...udio_4.asp
Post #145475 17th May 2012 8:51am
jayaway44
2012 Defender 110 Puma 2.2 USW Stornoway Grey
Re: Sensors fitted without drilling holes
Do you by any chance have some pictures of the installation.
Thanks AJS 2.2 2012 110 utility Orkney Grey
Also
Range Rover Evoque - Surprising but I like it.
Previous
Freelander 2 SD4 HSE - Black
90 TD5
Discovery 3
Early Discovery.
Post #148850 6th Jun 2012 7:05am
Gil9713
AJS,
Sorry mate, as there were so many on the site anyway, didn't bother, but I did opt for the easy solution which was to use the fifth hole on the rear bumper.
If you look you'll see four holes on either side. It was the lower fifth one I ran my cable through.
Does what it says on the box. As soon as you put it into reverse you get a beep, and as you back up the sensors alarm constantly with a continous beep when you have reached approx 12" from the obstruction. The good news is, thats 12" from my tyre on the back as well so it is a good simple cheap option.
Post #148862 6th Jun 2012 9:04am
Page 2 of 2 <12
