Home > Puma (Tdci) > Is removing the oil sump pan difficult ?
Bundubasher
South Africa 2007 Defender 110 Puma 2.4 SW Chawton White
I have been told that removing the oil sump pan can be difficult because it is not sealed by your normal kind paper/cork gasket but by a special glue. Hence very difficult to remove the pan. Sometimes the pan might get bent in the removal process and then you have to buy a new one. If this is true then I must get a price on a new sump pan first, before I try to remove the pan. I am sure that I could get a very thin and flat piece of metal and slowly work the pan loose.
Thanks
Post #14454 20th Aug 2009 2:58pm
mse
I think they have been using a liquid gasket for a while now. Mike
Post #14462 20th Aug 2009 6:45pm
LESVOSD110
South Africa 2010 Defender 110 Puma 2.4 SW Fuji White
Hi.
I used permatex gasket sealer on my v8 sump and removal is not so difficult.Used a rubber mallet and a utillity blade to break the seal.Just don't be in a hurry!
George Puma 110 SW
90 V8 SOFT TOP
Post #14497 22nd Aug 2009 5:11am
