Home > Td5 > Can you ID these parts under my bonnet please?
RRUK
I was going to do the EGR removal on my TD5 so thought I had best look under the acoustic cover as mine falls around the change of type, and I found a few things that have been upgraded but I want to know what they are. I also need to know if the EGR looks like it has been done, so I took some photos.
Please help if you can!
1. Looking from the OS front wing - this is where the EGR bit sits, yes? So what I have got here?
And again from the front:
2. Now, looking from the NS wing you can see the following - but I don't know if it means it is std or not?
3. Is that the EGR blanking part, just behind the radiator at the front of the engine?
4. I also seem to have more of the S/S pipework going from the bottom of the turbo to the front of the car. Not sure what it goes into, maybe the intercooler?
5. Finally, this is looking at the back of my NS headlight and wing. At the bottom you can see a brown rectangular electrical connector - does anyone know what it is for?
 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #144080 9th May 2012 10:06am
RRUK
Having just read the PDF from Alive Tuning on how to fit the EGR kit, I think I am 99% sure it has been done, the only thing that is different is that the in-line heat exchanger in front of the engine has not been blanked off on the NS end. I'm not sure if this makes any difference? 2016 D4 HSE
Post #144081 9th May 2012 10:23am
Martin
Site Admin
Hi Adam,
Yes it's already had the EGR deleted. In photo 1 & 2 the pipe with the harness cable-tied to it is the EGR valve replacement pipe. In photo 1 the welded pipe is coming from the "cold" side of the intercooler.
Photo 3 is the EGR "feed" from the end of the exhaust manifold (standard).
Photo 4 is a blank fitted to the "cold" end of the EGR cooler.
Clearly it's been done here rather than at the exhaust manifold (hot) end as they've not needed/bothered to remove the cooler.
Photo 5 & 6 - yes the pipework goes off to the intercooler.
Has your 90 got a deeper intercooler? That pipework and blue silicone hose isn't standard!
Photo 7 - headlamp levelling plug (not fitted to your 90 as it's a hardtop)  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #144083 9th May 2012 10:27am
Martin
Site Admin
No difference to functionality blanking off from the cold end, just a bit lazy to do it there as the redundant cooler is still in place.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #144084 9th May 2012 10:27am
robpenrose
Is the actual EGR valve still inline though? It's on the other side of the engine to the turbo?
I used one of the Alive Kits which came with a bit of pipe that means you can remove the valve all together.
You haven't got a picture of it do I can't see... Current:D4 HSE
Gone: BMW Z4MC
Gone: Defender TD5 90 CSW
Previous: Discovery TD5 ES (Gone)
Post #144095 9th May 2012 11:05am
robpenrose
Ah Sorry, just looked at Picture One again and that's the shot where the EGR valve is. Looks like its been completly removed... Current:D4 HSE
Gone: BMW Z4MC
Post #144096 9th May 2012 11:07am
party monkey
England 2005 Defender 110 Td5 XS CSW Cairns Blue
PM sent ref photo 7.
I'm pretty sure it's not the headlight levelling motor from my own discovery/experience. Jon - 110 td5 [sold]. Currently Defenderless.
Post #144097 9th May 2012 11:07am
RRUK
How can I tell if its got a deeper intercooler? (other than removing the grille and posting a photo for you to look at? 2016 D4 HSE
Post #144099 9th May 2012 11:20am
Martin
Site Admin
Post a photo looking through the grille Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #144103 9th May 2012 11:41am
Martin
Site Admin
Good point Thumbs Up  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #144104 9th May 2012 11:41am
RRUK
OK< here you go then.
 2016 D4 HSE
Post #144108 9th May 2012 12:18pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Looks to me as though that's defiantly standard 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #144111 9th May 2012 12:34pm
Martin
Site Admin
Looks standard to me - wonder why it has those replacement pipes on it then?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #144113 9th May 2012 12:38pm
RRUK
to look shiny maybe? Whistle 2016 D4 HSE
Post #144114 9th May 2012 12:41pm
big steve
Lol
Personally go and buy the right pipes that fit as yours don't look right with those Ali bits and get a nice big intercooler
And a remap from bas and a nice full stainless system it will be worth it I loved the sound of my td5
Steve 2015 2.2 tdci hardtop xs
Post #144126 9th May 2012 1:29pm
