Home > Puma (Tdci) > New key . . . Anyone noticed any defference
Jammer600
United Kingdom 2007 Defender 90 Puma 2.4 HT Tonga Green
Hello, just wondering if anyone's noticed that the winkers take a while longer to flash, also, got outta mine yesterday, left keys in as normal, went bk 5 mins later, tried starting, turned over but no fire then was like it had a flat battery, my gues was the immobiliser had kicked in, took keys out, locked and unlocked and started up fine? Cheers jammer 90 Puma HT
Post #143478 5th May 2012 8:23am
Odin
Scotland 2012 Defender 110 Puma 2.2 USW Santorini Black
No difference. Yes, immobiliser. You should have seen red indication near bottom of left hand dial.
Post #143483 5th May 2012 9:49am
spudfan
Ireland
My 2011 Puma came missing one key. I got one ordered in and it was arranged for my nearest dealer to programme it.This is not where I bought the vehicle. When this key is inserted, the red light on the dash stays on and the vehicle will not start. When the lock/unlock blip is used and key inserted and turned, the vehicle starts. This leads me to think it is a programming glitch as the original key works fine. I don't think it is much to worry about, just lock/unlock before you start. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #143501 5th May 2012 2:46pm
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
You do have 2 of the " lock/unlock blip's" or FOB's , one for each key? Because it is the FOB which contains the chip/electronics for the engine immobiliser not the key and the FOB has to be close to the antenna in the steering column. Whistle LANDYWATCH
Neighbourhood Watch for Land Rover Owners
http://www.landywatch.co.uk/smf2/index.php
Post #143528 5th May 2012 9:17pm
Jammer600
It's a key with built in fob, the group buy jobby Smile 90 Puma HT
Post #143567 6th May 2012 10:16am
spudfan
Ireland
Yep, my second key has the fob, so I still maintain it is a glitch with the programming. 1982 88" 2.25 diesel
Post #143570 6th May 2012 10:31am
WelshGas
In that case you are probably correct. The programming is not correct. Thumbs Up LANDYWATCH
Post #143576 6th May 2012 10:46am
Jammer600
It came with a pod thing to program it?! It does work it's just once this happened?! Just wondered if anyone with the same key had this!? 90 Puma HT
Post #143583 6th May 2012 11:17am
Fifth Horseman
I've had a similar problem with both the original fob and the combined fob/key.
At random intervals the engine will turn over, almost start then stop, further attempts to start result in the engine not turning over, a lock/unlock cycle usually results in an instant start.
I would guess that it is an immobiliser problem but have not had the time (or the Nanocom with me) when it happens to diagnose in more depth.
Post #143590 6th May 2012 1:17pm
Fifth Horseman
Deleted duplicate post - must learn not to use 'previous page' button after posting Embarassed
Post #143591 6th May 2012 1:17pm
Lorryman100
Try resynchronising the fobs to the 10AS. They do go out of synch sometimes and the pre programmed resynch is to lock and unlock using the fob 4 times. Thumbs Up
Brian
Post #143600 6th May 2012 3:46pm
