![]() | Home > Puma (Tdci) > advice on a starting problem... |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Sounds likely to be EGR again.
Get it back to the dealer ... it's still under warranty ![]() Mine played up like crazy, had 3 EGR valves under warranty ... as soon as warranty expired i had the EGR 'mapped out' along with a re-map by IRB Developments ... best thing i ever did ![]() |
Markh Member Since: 24 Jul 2010 Location: Grantham Posts: 33 ![]() ![]() ![]() |
Thanks Dave sound advice
One question, what benefit did you see from mapping out your EGR? is it just to remove the pain of it failing or have you seen some performance / fuel econ benefit? "Twenty years from now you will be more disappointed by the things you didn’t do than by the things you did..." |
Mainly it removes the hassle of an on going problem ... but i had mine done along with a performance re-map. Difference is amazing! It drives like a completely different motor [a bit quick too ![]() |
