Home > Tdi > anti roll bars |
lambert.the.farmer Member Since: 11 Apr 2012 Location: harrogate Posts: 2006 |
Hi all. Quick question. Did all late 300 commercial 90's have anti roll bars as standard? Rhubarb and custard let fly with their secret weapon.
4th May 2012 3:09pm |
mine doesn't - could do with some
4th May 2012 3:54pm |
An option then. Goodo. I will look at binning mine then, see if that helps with wheel lifting tripod action. Rhubarb and custard let fly with their secret weapon.
4th May 2012 7:20pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
no need to remove them for greenlaning in the uk. only if you're doing pay / play or events.
26th Jun 2012 10:18am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8026 |
i have a set here, front and rear off a 110 08 plate and a rear off a 10 plate 110 up for grabs. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
26th Jun 2012 8:42pm |
I do neither of those trhings. But I can report I now seem able to keep all my wheels on the deck even where before I had two wheels off not now. Rhubarb and custard let fly with their secret weapon. |
30th Jun 2012 11:36pm |
James - sorry I missed your post... 1. would they fit a 95/300/90 ? 2. how much would you like for them? |
1st Jul 2012 6:16am |
i believe so yes. fronts are def would need to check on the rear. you after front and rear? will double check where the are and get some dims/pictures if you want? price wise, dunno, what they worth to you? ie make an offer. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
2nd Jul 2012 9:23am |
hi James
yes, front and rear please ... I'll PM you an offer |
14th Jul 2012 6:33am |
Lookers Park Royal Member Since: 19 Jun 2008 Location: London Posts: 338 |
I have ARB's on my 90 300 Tdi which was a pick-up, and do a fair bit of laning and RTV trialing. To be fair unless you are looking for excessive articulation then you'd probably be fine with them fitted.
I would rather have them on for all the benefits of on-road cornering and compromise with a bit of wheel lifting off road. James |
14th Jul 2012 12:01pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Concur with James I fitted front and rear to my 90 about 3 years ago as it was a bit 'wallowy' on the road .. what an absolute difference! Drives so much better, and not noticed any difference when laning/off roading - still go's everywhere it did before Guns and Landrovers .... anything else is irrelevant. |
14th Jul 2012 12:34pm |
SteveRat Member Since: 01 Aug 2012 Location: Chester Posts: 7 |
I'm also in the market for ARBs. My 94 county 90 has the mounting points but no ARBs - so pls let me know if you have a spare set you want to flog. I use mine for towing and feild work but nothing extreme, I just want to cut down on the rolling in the corners.
Cheers Steve |
1st Aug 2012 9:11pm |
