Home > Puma (Tdci) > 500 vs 50 ppm diesel |
Marius Member Since: 21 Dec 2010 Location: South Africa Posts: 231 |
is 500 ppm diesel bad for the 2.4 puma?
4th May 2012 6:17am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2648 |
Marius, it can handle it. IIRC, it can handle up to 3000ppm. But fill up with 50ppm as a rule, it's a much better diesel. I find the best consumption comes from Sasol and Shell -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
4th May 2012 6:44am |
It won't. However, higher sulphur content means more sulphuric acid in the oil. Just change the oil every 10,000km to get rid of the sulphuric acid build up -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
4th May 2012 7:03am |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 |
The main problem using 500ppm is that it stuffs up the DPF, which isn't installed on SA vehicles. But Naks is correct about the acid build up when using 500ppm. The service schedule states that if you use 500ppm then you should reduce oil changes to 10k. Fill up with 50ppm where you can. |
4th May 2012 7:56am |
the 2.2 Puma has a DPF, so be careful -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
4th May 2012 8:02am |
Not in South Africa. |
4th May 2012 8:04am |
Oh, didn't know this. Good to know -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
ok......50ppm it will have to be then.
I live 4 km from work so I end up getting to 1 year before I get to 20k. Had my first years service at 12k so, should be ok with the acid buildup then. |
4th May 2012 9:44am |
Not that great to do such short distances every day. I would take it out on the open road at least once a week to give horns -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
4th May 2012 10:00am |
bwanashamba Member Since: 03 Jan 2012 Location: tanzania Posts: 14 |
here in Tanzania diesel fuel is all 5000ppm except BP which is 500ppm,where we are we cant get BP The dealer insists that service is done every 5000km to stay in warrenty, so far no problems with the high sulpher fuel, on about 16000km now
4th May 2012 11:58am |
