Home > Maintenance & Modifications > Tyre pressure
Timo
Canada 1984 Defender 110 300 Tdi SW Alveston Red
Tyre pressure
Hi all
I just got a set of BGF All terrain T/A ko in 238/85 R16.
The tire shop installed them and has them all at 60psi when I picked them up. This seems a bit high, although the max psi says 80 on the sidewall, any insight is appreciated?
Thanks
T_ Series II in pieces
1984 Defender 110 (3.5l V8 now 300TDI)
Post #143172 3rd May 2012 12:06pm
MartinK
I usually run 30 psi in the fronts (recommended in the manual)
36 psi unloaded or 40psi loaded in the rears (manual says 38psi unladen, and up to 65psi fully-laden).
Any more (than 38psi) and the ride quality becomes (in mine at least) too bouncy. Go too low, and your fuel consumption will suffer...
You may want less pressure for offroading. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #143175 3rd May 2012 12:10pm
TR51
France 2014 Defender 110 Puma 2.2 SW Corris Grey
Chalk Test
I run 32psi in the front and 40psi in the rear (takes into account the extra kit carried).
Tyre center did the same when my 265 BFG AT's went on but a friend told me about the chalk test...
See http://www.ehow.com/how_6948382_chalk-tires.html for a page describing it.
Ensures your tires are exactly correct for the equipment you carry Thumbs Up
Post #143182 3rd May 2012 12:51pm
bm52
United Kingdom 2014 Defender 110 Puma 2.2 XS CSW Havana
i have the same tyres on my 90. 30 front and currently 38 lightly laden on the rear BM52
Post #143188 3rd May 2012 1:35pm
Naks
Re: Tyre pressure
Wayyyyy too high.
I run mine unladen on 2.5bar all round --
Post #143192 3rd May 2012 2:04pm
Merlin
My 110 Puma handbook says 35 front, rear 45 or 65 if towing/laden.
Merlin
Post #143216 3rd May 2012 4:41pm
Timo
Thanks guys. I guess the garage had no idea if I was towing of what my weight would be (of the rover that is....)
I will play around with the 38-40 range and see how that handles/rides.
Tim Series II in pieces
Post #143282 4th May 2012 1:58am
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Merlin
Thumbs Up mine too, 35/45 and she runs good.
i think there is a difference between 90 and 110. www.newfoundland.gr
Post #143287 4th May 2012 5:34am
Froggy
South Africa 2010 Defender 90 Puma 2.4 CSW Blenheim Silver
I run my BGF's
Front 1.9 bar
Rear 2.3 bar
On gravel/dirt roads I drop them by 0.4 bars.
On sand and most mountain trails (loose scree etc) we would drop them to 1 bar all round.
Apart from better traction, it will also cause less damage to the trails.
Froggy. Flying the flag in a country full of Toyota's!
Post #143621 6th May 2012 4:59pm
Regard
South Africa 2011 Defender 110 Puma 2.4 X-Tech LE Orkney Grey
I've got BFG M/T on and run 1.9 front and 1.8 rear.
Nice smooth ride and even tread wear Thumbs Up
Post #143929 8th May 2012 11:05am
Naks
Froggy wrote:
I run my BGF's
Front 1.9 bar
Rear 2.3 bar
When overlanding I use the following rule:
1. Take the axle weight / 2 (two wheels) and divide by wheel carrying capacity (in my case 1550kg) and multiply by the tyre pressure at max load (BFG AT = 5.5)
Total vehicle weight: 2500kg
Front axle: 1150 (46%)
Rear axle: 1350 (54%)
Pressures
Front: (1150/2)*(5.5/1550) = 2.04 (round off to 2.1)
Rear: (1350/2)*(5.5/1550) = 2.40 (round off to 2.5)
3. When you get to gravel, measure actual tyre pressure (call it AP), deflate to half.
4. When you get back to tar, re-inflate to AP
5. For offroading on rocky trails, drop to 1.2-1.5 bar all round
6. For sandy trail, drop to 1.0-0.8 bar all round --
Post #143931 8th May 2012 11:14am
bm52
Just copied this from the Puma workshop manual
90 - 265/75 R16
1,9 bar 2,4 bar
28 lbf/in 35 lbf/in
90 - 7.50 R16
1,9 bar 2,6 bar
28 lbf/in 38 lbf/in
110 - 7.50 R16 (except Japan)
1,9 bar 3,3 bar
28 lbf/in 48 lbf/in
I had been running my front at 30 as directed by the handbook, just dropped them to 28 for a few days to see how it feels, also put the rears back to 36 which seems to feel right Confused BM52
Post #144021 8th May 2012 8:46pm
excossack
My 235/85 16 BFG ATs run at 36psi front and rear so far seem OK. 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #144032 8th May 2012 9:21pm
