Home > Maintenance & Modifications > Terrafima winch and bumper - susp mods?
familymad
About to fit a winch and bumper as stated above. Has anyone done this without changing the front springs? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #142041 27th Apr 2012 10:24am
bob neville
Yes, TF tubular winch bumper (non A bar) and SW Talon fitted on my 2009 110.
No suspension mods and it is fine.
Edit - a picture
2013 Defender 90 CSW - sold
Post #142054 27th Apr 2012 11:14am
familymad
Thanks Bob,
That looks hardcore..........nice one 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #142058 27th Apr 2012 11:27am
bob neville
Ta Thumbs Up
I have a pair of TF light upgrade front springs sat at home that I was going to fit to level things up a bit but to be honest I don't think I will fit them now.
After you have fitted your setup, if you think you want heavier springs for the front you can have the TF springs for what I paid for them (£60) plus P&P if you want them.
Post #142062 27th Apr 2012 11:42am
familymad
They sound good. Will fit it on Monday so get back to you
Cheers 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #142064 27th Apr 2012 11:51am
familymad
Are they TF014's? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #142067 27th Apr 2012 11:55am
Zagato
Re: Terrafima winch and bumper - susp mods?
Mine was fine on standard set up, even improved the ride over ruts but it's a hell of a weight, like having someone sitting on your bumper all the time so I took it off as didn't need it and the money came in handy!
Post #142069 27th Apr 2012 12:01pm
Going out on a limb here, I would suggest the majority of winches sitting on the front of Defenders are 'not actually needed' ...... Whistle
Post #142072 27th Apr 2012 12:08pm
bob neville
familymad wrote:
Are they TF014's?
They are Thumbs Up
"Going out on a limb here, I would suggest the majority of winches sitting on the front of Defenders are 'not actually needed' "
Depends I suppose. Mine is fitted for a purpose and is used. Others fit just for looks.
I was questioning the expense of fitting one for a long time as it never got used for 6 months but paid for itself time and time again on the Exmoor 4x4 last month Thumbs Up Even if it only gets used for one event a year it has now justified it's existence Thumbs Up
Without it I would probably still be stuck on Exmoor, hmmm .... maybe I should get rid of it Rolling with laughter
Post #142085 27th Apr 2012 12:27pm
Lishlandy
England 2012 Defender 110 Puma 2.2 X-Tech LE Orkney Grey
makes for a very sturdy washing line on a weekend camping trip. Thumbs Up ===================================
Steve
90 xs sw in Stonoway Grey - Sold
110 USW X-TECH
Post #142095 27th Apr 2012 12:52pm
bob neville
Certainly does Thumbs Up
Post #142099 27th Apr 2012 12:54pm
noworries4x4
While i was swapping my 57 over to the 12 i did not have my winch for 2 weeks and as above i had not touched it for nearly a year then the law of sod stepped in and i needed it badly the weeks it was not there that was a pain in the rear, the job took 10 times longer. If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle
Weekends 07MY L322 TDV8 Vogue SE
No Worries 4X4
Post #142224 28th Apr 2012 9:01am
familymad
Most of you guys seem to be able to fit their winch with no grille modification? 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #143966 8th May 2012 4:20pm
bob neville
I had to butcher the grill to get the SW Talon to fit. However, the Talon is slightly larger than most winches.
Post #143981 8th May 2012 5:45pm
familymad
Looks like the grill will have to be modded........ 1951 80" S1 2.0
1995 110 300TDI
1995 90 300TDI
Post #149817 11th Jun 2012 8:57pm
