![]() | Home > Technical > webasto fuel tap anyone ? |
tatra805 Member Since: 16 Aug 2011 Location: Dolany Posts: 436 ![]() ![]() ![]() |
I dont have part numbers but it is a standard pickup tube from webasto itself.
Each webasto truck center should have them on the shelves as most commonly used. The tube is a 60mm piece of alu or stainless, drill hole, fit pickuptube and ready. ![]() |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 ![]() ![]() ![]() |
bpman - have sent you a PM
sorry Pom the webasto kits come with a plastic "T" to splice into the fuel lines. Both the Land Rover and Webasto land rover instructions show the "T" being used. But like Tatra805 says, it puts alot of pressure on the webasto pump and possibly the heater unit. |
LRSoffroad Member Since: 15 Feb 2012 Location: Doncaster Posts: 189 ![]() ![]() |
bpman webasto has spent ££££ in development and the instructions I have and Ian, are from Germany webesto but was developed and fitted by a mate of mine here in Doncaster that is now head of military fitting and development for the whole webasto group so any problems they have with feed etc. would have been and have been tested but any questions pm me and I will put them Straight to the horse’s mouth, so to say
cheers Derrick, I will see you at the farm in May, I will also bring the Swiss LHD webasto mounting kit up for you to see. I'm not going to fit it until we move house and I'm going to do a "drop the tank" installation.
no probs Bpman see you there , are you putting a drop pipe in the tank as in the photos??
hi Derrick You have an email ![]() cheers steve |
monty.shadsworth Member Since: 01 Dec 2012 Location: st.helens Posts: 2 ![]() ![]() |
hi all. ive got a split fuel return line issue. its gone on the 3rd injector nossel conector point. snapped clean off. cant go back on. any ideas on repair and or were to get a replacement. ie searched nett and ebay to end. just a wippet from shadsworth
