Home > Puma (Tdci) > Fuel restriction
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
Fuel restriction
Iv got a problem I'm getting a fault that basically means my injectors arnt getting enough fuel
Any body got any possible solutions ?
Steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #140891 22nd Apr 2012 5:19pm
sense of adventure
United Kingdom 2010 Defender 110 Puma 2.4 USW Galway Green
Hi, does your fuel gauge work properly or are you getting this when you are low on fuel? The ecu reduces fuel to the rail to reduce power when you are/or it thinks you are low on fuel.
Post #140919 22nd Apr 2012 6:54pm
big steve
hi fuel hauge works fine it comes up with 4 fault codes identifying that each injector is on restricted fuel
but what you say could be right as i remeber that the freelanders go into limp mode when they get low on fuel ?
i am going to change the fuel filter anyway but it just concerns me a little
steve 2015 2.2 tdci hardtop xs
Post #140956 22nd Apr 2012 8:10pm
robharvey
South Africa 2009 Defender 110 Puma 2.4 SW Alpine White
I also get the fault codes, but only when the vehicle is running (untested fault codes, I think). I tested another Puma the other day and it got them as well. At my last service I asked the dealer to check the injectors and they gave them a clean bill of health. My advice - don't worry.
Post #141030 23rd Apr 2012 6:01am
big steve
Yer that's right hmm taken my mind off it a bit now cheers
Post #141033 23rd Apr 2012 7:15am
