Home > Technical > LED bulbs
AlpenAndes
Austria 2010 Defender 110 Puma 2.4 SW Belize Green
LED bulbs
Hi,
I was thinking about changing to LED bulbs. Anyone who did that already can tell me if white LEDs behind coloured plastic give the desired colour or does the break light come out pinkish and the indicator yellowish? Any experience with particular LED bulbs, like the number of LEDs per bulb, how do superbright look like?
Last question, as I was looking on pages in the UK to order, they use number coding while my spanish manual uses letters. Anyone who has a list that shows the correct numbers. In particular I am not sure about the side indicators and the number plate.
Thanks in advance for your help
Oskar
Post #139705 16th Apr 2012 11:48pm
AlpenAndes
do you mean in the dashboard or front/rear lights ?
Post #139721 17th Apr 2012 6:27am
AlpenAndes
I was primarily thinking about front and rear lights.
Post #139807 17th Apr 2012 11:48am
there's quite a few companies selling LEDs, I use ULTRALEDS.co.uk, I've had mine for years in various trucks. if you are going to fit indicators, you can get yellow/amber ones but you will be best fitting load resistors rather than a LED indicator relay as you may tow a trailer or caravan.
My 90 has tail/stops, side lights but not indicators yet
Post #139879 17th Apr 2012 5:10pm
AlpenAndes
Perfect, thanks. Do you use white behind the coloured plastic or coloured LEDs with white plastic? I want to use the coloured plastic with white LEDs but I am not sure how the colour turns out.
BR
Oskar
Post #139920 17th Apr 2012 7:12pm
the amber and red leds are usually clear until they are lit, so if you have clear/white lenses, they will be fine.
Post #139927 17th Apr 2012 7:27pm
AlpenAndes
ok, thanks a lot for your help.
Post #140001 18th Apr 2012 1:57am
IF you go the LED bulb route think before you buy as LEDS sort of project light in a different way to filament bulbs so unless some leds point towards the reflector in the unit you will not have proper lighting
Post #140009 18th Apr 2012 5:34am
Absolutely Ken, the stop/tails on ultraleds have leds all the way around, I have had a few trucks mot'd with these led bulbs and no problem, ever white/led front sidelights
Post #140019 18th Apr 2012 6:35am
