![]() | Home > Td5 > Thermostat change |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8155 ![]() ![]() ![]() |
is there a constant draw of air felt on the front of the vehicle. when a viscous is locked up you can normally feel the draw of air from them. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
jwhat Member Since: 19 Jan 2011 Location: Westmeath Posts: 134 ![]() ![]() ![]() |
I'll check at the weekend when I get back to the 90. Thanks for the tip. Tdci 110 DC |
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 160 ![]() ![]() ![]() |
Measured it should be 88.2deg c. When sitting idle.
Needle on the gauge sits slightly to the left from Center. This assumes your sender n gauge are correct. What you are getting with the above assumption is around 64deg. The gauge is not linear. From the land of the most expensive land rover defenders on planet earth. At �125k for a XS 110 csw and you get to own it only for 10yrs! Please find me a good reason to stay on this island. |
