Home > Puma (Tdci) > Tip broken off Oil Dip Stick
Bundubasher
South Africa 2007 Defender 110 Puma 2.4 SW Chawton White
Hi. I noticed yesterday that the part of the dip stick that measures trhe oil level has broken off. It is made of some aluminium alloy I think. The dealer says this could cause serious damage so the sump must be removed. Anybody else had this problem.
Thanks
Anthony
Post #13914 7th Aug 2009 7:19am
mse
No but i would agree with the dealer. Mike
Post #13919 7th Aug 2009 9:18am
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
Mine seems to need a good yank to pull out the first inch and then it comes out smoothly. I think i'll check it before it snaps. 130 crew cab
98 V8 Disco
Post #13941 7th Aug 2009 2:05pm
CapeLandy
South Africa
I noticed on mine that the edges where it is crimped onto the wire cord are cracked and pieces of metal are flaking off. I pulled off all the loose pieces and straigtened the end which was also a little kinked to one side.
Hope it stays atached- maybe you will get a free oil change while they hunt for the end of yours Confused Puma 110 - gone
Series III 1973 - going strong
Post #13947 7th Aug 2009 5:03pm
