Home > Maintenance & Modifications > How far can handbrake vibration travel? |
Is it possible that handbrake drum banging/movement is carried efficiently through the transfer box and into the gearbox where it interferes with gear changing?
I noticed today that when coasting (clutch in) with the brake drum banging away, pushing the stick from neutral to third got a lot of "knocking" action (similar to what I usually get when driving). Feathering the handbrake got rid of the banging and neutral to third became smooth... Matt p.s. For those who will mock me - no, I still haven't got around to whipping out the shoes yet Tell someone you love them today because life is short. But shout it at them in German because life is also terrifying and confusing... |
13th Apr 2012 7:56pm |
Think the props are okay but skimming the drum may be an idea - just need to get through the next 2 years and LR aren't having much luck - must be a lot of "bad drums" out there... I've had 2 already Tell someone you love them today because life is short.
13th Apr 2012 8:50pm |
