Home > Puma (Tdci) > Heat safe mode |
BruceT Member Since: 01 Nov 2010 Location: South Africa Posts: 518 |
Great thanks Naks.
13th Apr 2012 10:54am |
Regard Member Since: 08 Dec 2011 Location: RSA Posts: 251 |
Hi Bruce
I have also struggled with a simmilar problem. I am not sure it is the same symptoms but mine is a perfect running car up to 120km/h and then as soon as it gets a bit warm outside the car struggles to stay at 110km/h. So not a massive powerloss but you can feel there is less power. I have also struggled with a simmilar problem. With my Ultra-Gauge I have noticed that as soon as the inlet temp moves above 34degC the ECU cuts back on the Fuel Rail Pressure as well as the boost pressure. Now, in the cooler climate, it doesn't do it at all and my inlet temps almost never goes above 27degC. So, my waranty runs out in September. Gues what my first up-grade will be........yip, intercooler and silicone hoses. |
13th Apr 2012 11:11am |
On the Ultra-Gauge I have noticed that it has nothing to do with coolent temp but only gets influenced by INLET temp. And inlet temp and coolant temp doesn't seem to be correlated. |
13th Apr 2012 11:22am |
robharvey Member Since: 14 Dec 2009 Location: Durban Posts: 86 |
I also get this. Spoke to the service manager at LR Vereeniging, Giovanni, who tells me the fix is a larger intercooler which he gets from Elton at Turbochip (or whatever he is called now). Elton quoted me ZAR4.5k ex VAT (I think). Giovanni was at pains to point out that it is not a LRSA approved mod, but definitely solves the problem of the power-down on hot days.
Regarding why it happens to some Pumas and not others I think it has a lot to do with driving style. Mine occurs when it's hot and I'm ascending a hill, but only after I've been gunning it for a long period. If I've been driving sedately it won't do it. |
13th Apr 2012 11:40am |
Thanks all for the replies. I have sent Winston a mail with the link so hopefully he will see this.
13th Apr 2012 11:52am |
Eduardo Member Since: 28 Aug 2008 Location: RegiĆ³n Metropolitana Posts: 2110 |
Similar problem here appears during hot weather after several hours of driving.
Probably a new intercooler will be the solution in the long term. Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" Click image to enlarge |
13th Apr 2012 12:05pm |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
OK, right so what we think is that it is the inlet temp that is causing the shutdown rather than the coolant temp, right? That makes sense but when mine did it was because the coolant got too hot (plastic bag over the grill) so maybe it does work both ways. Think I may look into this more when I get a few spare hours and try to reproduce the conditions that mine overheated.
Very interesting thread |
13th Apr 2012 1:01pm |
Keep us in the loop! |
13th Apr 2012 1:42pm |
