Home > Maintenance & Modifications > Compressor Connection |
mudrut Member Since: 29 Feb 2012 Location: Stourport-on-Severn Posts: 80 |
Agree with above that an Anderson connector on the front of the battery box is the way to go. Every time I buy a new truck, it is one of the 'standard' mods that gets done.
I have a set of booster cables with an Anderson connector stashed in each truck for emergencies and any compressor that I buy also gets fitted with an Anderson. When the trucks are parked up, I use a C-TEK battery charger to keep the batteries happy and have made up quick-connect charging cables by cutting the eyelets off the cable that comes with the C-TEK and putting an Anderson in their place - again, much easier than lifting the seat base. I recommend that you solder cables into the connectors rather than buy the expensive crimping tool. In my opinion, it makes for a better connection anyway. It's worth knowing that Warn supply a booster connector kit (Warn PN 26769). This is an Anderson with a 4' length of heavy duty cable on it terminated with battery eyes which can be bolted to the front of the seat box as you would expect. The other part of the kit is a very heavy duty, high quality set of 5 metre booster cables. The price is something like £140 if I recall correctly. It does save a lot of time and aggravation and gives a top notch end result. You can then buy any number of Red 175Amp Anderson connectors for your accessories Ahhh - just found some links: Warn Booster Cable Kit Additional Red Anderson Connectors Hope that helps. regards Ian |
12th Apr 2012 1:41pm |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8580 |
You may find this thread interesting reading. The way we wire up the Anderson connector is straight onto the battery. Yes you could use an isolator switch in line with it but to what purpose? Yes you have permanent 12 volt supply unfused but it is at same height as battery so no more liable to water damage then main battery You could put a mega fuse in line with it but for engine starting it would have to be a decent size one. Brendan |
12th Apr 2012 5:07pm |
good call Steve, I would definately install a megafuse, alot cheaper to replace than a PC1500 |
12th Apr 2012 8:54pm |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
Thanks Brendan... I had missed that thread! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
13th Apr 2012 10:41am |
MartinK Member Since: 02 Mar 2011 Location: Silverdale (Lancashire/Cumbria Border) Posts: 2665 |
Great idea - I use a CTEK when the vehicle isn't being used for a couple of weeks or more in winter - this is a good solution, I'll get that done, and also (as per the thread), I can plug-in other accessories much more easily. Thanks for sharing. Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's) |
13th Apr 2012 11:21am |
