![]() | Home > Td5 > Vibration |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 ![]() ![]() ![]() |
Hiya Gary
![]() Try checking the propshaft UJ's, known weak point Could also check wheel balancing . they'd be the first two items to concentrate on ............... Guns and Landrovers .... anything else is irrelevant. |
also, if the suspension has been raised or lowered can cause vibrations - double cardon props fix that
mudrut Member Since: 29 Feb 2012 Location: Stourport-on-Severn Posts: 80 ![]() ![]() ![]() |
Hi Gary
Has this just started happening? Did it just come on over time, or after a change made to the vehicle? regards Ian |
