![]() | Home > Technical > Best way to route wiring |
Simon
You should be able to connect the camera to the reversing light +ve, there (may) be a purple/black permanent feed (there is in 110's) as for routing, how about some convoluted trucking and tuck it under the truck ? VWP (vehicle wiring products) are about the cheapest for that stuff, then up through the bulkhead at the front through an existing hole. pics please ! |
bm52 Member Since: 04 Apr 2010 Location: Kent Posts: 2189 ![]() ![]() ![]() |
If you have a live feed at the rear could you feed the wires up the rear corner and then along the ledge by the alpine light and tuck under front headlining
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 ![]() |
Rear 12volt power point:
Simon - I'd be interested to know if 130's have the purple/black wires ? |
SGH Member Since: 27 Sep 2010 Location: Hellingly-Sussex Posts: 1527 ![]() ![]() |
Unsure if to route from mirror down passenger or driver side in cab, rear connection not a problem as I plan on routing from camera along the chassis as it's a double cab.
Simon 993 Varioram - Guards Red Defender 2.5 300TDI 110 HCP - Keswick Green Defender 2.2 TDCI 130 HCP - Orkney Grey - GONE Discovery 4 SDV6 HSE LUX - Corris Grey/Black Pack - GONE Discovery 4 SDV6 HSE LUX - Montaciano Red/Black Pack - GONE |
I would guess the same side as the reversing light, that way you don't need to cross left/right over the chassis.
How easy is it to gain access behind the dash to get a live feed on drivers side. 993 Varioram - Guards Red
there's 4 screws to remove the instrument binnacle, then once removed it's pretty easy to get the centre part of the dash, you can also get good access to the fuse box area, so should be pretty easy.
do you have downloads of all the wiring diagrams ? |
