Home > Puma (Tdci) > Oil leak - warranty advice |
jamesc Member Since: 19 Nov 2010 Location: Elsewhere Posts: 74 |
Hi all,
A little advice if possible. Discovered a small leak from the rear diff at the weekend on my 61 plate 2.4. Obviously I can get it fixed under warranty, but I would rather take it to an independent than the dealer (who anyway are rather a long way from home). The indy is here: http://www.lrsengineering.co.uk/ Can I do this without affecting the warranty? Also the oil coming out looks pretty back and dirty for only 3500 miles. Can I get them to do an oil change for both diffs as part of the warranty claim? Thanks in advance. |
3rd Apr 2012 9:59am |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2411 |
Sometimes a diff oil leak means the pinion is not properly tight. Puma 110" SW
4th Apr 2012 2:17pm |
