Home > For Sale & Wanted > WANTED Warn 9000 0r 9500 Winch |
noworries4x4 Member Since: 24 Dec 2010 Location: Newton Abbot Devon Posts: 1195 |
My winch has siezed up any one got one sat around wanting a new home ?? If everything is under control you are not going fast enough.
Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
2nd Apr 2012 6:26pm |
Winter salt has corroded the ally cassing and the motor bearings are a propper mess, linings on discs blistersd and distorted. Cheaper to find a new one If everything is under control you are not going fast enough.
3rd Apr 2012 4:40pm |
jwhat Member Since: 19 Jan 2011 Location: Westmeath Posts: 134 |
Wow that sounds bad, I'll be getting a cover whenever I get my winch so. Tdci 110 DC
3rd Apr 2012 4:52pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17344 |
Yup, that's the trouble with the cheaper Warn winches. Although I have a 9000 on the Disco, I would never buy another - Superwinch Husky is the way to go. |
3rd Apr 2012 4:57pm |
I am looking at either the goodwinch g5 9500i from David Bowyer or a Champion winch from Extream both the same sort of money. If everything is under control you are not going fast enough.
3rd Apr 2012 6:41pm |
Projectblue Member Since: 22 Nov 2011 Location: Devon Posts: 1096 |
Well that's an easy answer.
1. Goodwinch are brill and David Bowyer is great to deal with - have a look at the TDS Goldfish. 2. Champion are cheap and there's a lot of information about Extreme and the owner kicking around if you care to look |
3rd Apr 2012 10:15pm |
Good winch is most likely the route i am going down just cheking that it fits my bumper with out to much drilling and or cutting.
My heavy duty springs and anti roll bar are coming from Extream, i get on ok with them no problems with any of my srings on the TD5 or this Puma. The new one i am going for bigger roll bar than last time and slightly heavier springs than last time. Should be good. If everything is under control you are not going fast enough. Every Day 16 MY Discovery 4 Commercial Workshop and Escort Vehicle Weekends 07MY L322 TDV8 Vogue SE Series 1 80" 3ltr 6cyl with overdrive No Worries 4X4 |
3rd Apr 2012 10:38pm |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 5842 |
I've got a Goodwinch 12000 and its worked well winching out stuck rally cars! 1999 Defender TD5 110
4th Apr 2012 7:32am |
