Home > Technical > High Beam Wire Colour ! |
chalky Member Since: 09 May 2008 Location: Yorkshire Posts: 483 |
Hi,
Eventually getting round to wiring in my spots today ! In between the rain storms that we are having ! Of course i will check the wire with a multi meter but does any one know what colour the high beam wire is ? cheers ! DEFENDER XS CSW 08 TONGA GREEN |
30th Jul 2009 9:50am |
110SEB Member Since: 29 Jan 2009 Location: Essex, England Posts: 1444 |
Pics of the end job?
30th Jul 2009 3:29pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5054 |
Looks like Blue Red - RH and Blue Grey LH for main beam at the light. Check though Mike
30th Jul 2009 5:35pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6112 |
^^^^ What he said. |
30th Jul 2009 7:17pm |
Oh !
Now I'm panicking ! Blue / White tracer on mine eeeeek ! Seb I have take said piccys however I haven't got a clue on how to add them ? DEFENDER XS CSW 08 TONGA GREEN |
30th Jul 2009 8:12pm |
Jim,
Essentially relay, two power outs to each lamp, vehicle grnd / earth, live feed for switch, battery pos with in line fuse, two seperate earths from battery neg run with power outs from underneath the battery box in corrugated conduit along the chassis leg up the firewall round the fan heater matrix up under the inner wing to front of wing down into front and hey presto ! the negative and switched pos along the seat box and up under dash, pos to rear of switch and neg to chassis earth, anothe neg from same chassis earth back up to rear of switch and the other pin on back of plug to the high beam wire in the steering wheel cowling, Connect battery, keys in ignition and BINGO ! It works.................... DEFENDER XS CSW 08 TONGA GREEN |
30th Jul 2009 8:55pm |
cool! |
31st Jul 2009 6:36am |
