  • You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Technical > Window seals
Page 3 of 3 <123
Eduardo
The way that I use
www.imageshack.us
Click browse
Add the picture (be carefully with the size, no more than 600 x 400, if not the size will be too much)
Click start upload
wait until the picture appears (take some time)
Click in the picture uploaded
At the rigth side in the lower part you will found a section called embed this image
Click in the link at the rigth side of were said FORUM
Copy the link
Paste in your post
And voil�
If not work send me the pictures (eperezj@vtr.com) and I can post it.
Cheers Eduardo
Post #13582 29th Jul 2009 1:50pm
alantd
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Tonga Green
niglyn wrote:
[img][url][img][/img] [/img]
ok, i give up, how do I insert a picture of my window seal?[/url]
Upload it to the gallery and then copy the string that it gives you. There's probably a smarter way but I'm a simple chap. One that started out as a 2.4 TDCi 110 XS
+ New Defender 110 First Edition
Post #13586 29th Jul 2009 3:28pm
Happyoldgit
The doors have drain holes / slots in the bottom to permit water to drain out. You won't get a totally water tight seal between the glass, seal and frame.
Post #13589 29th Jul 2009 5:24pm
niglyn
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Agreed, one can never gat a 100% water seal, however the seal does not even touch the top of the paintwork, so every drop of water will end up in the door. Spoke to the dealer today. LR have agreed to pay for remedial work. They are going to grind the upstand where the seal fits onto down to lower the sal, so it will touch the door. Sounds like a recipe for disaster to me, some muppet with an angle grinder. They are bound to slip & totally f*** the doors up.
Post #13593 29th Jul 2009 6:37pm
Grockle
Don't let them they aren't safe with an airline let alone a grinder,live with it we have. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #13603 30th Jul 2009 9:05am
niglyn
Yeah, I agree. I might just pug up the gaps with mastic. I cannot see how they can grind down the top, the lip goes right to the edeges, no way to get a grinder in there. A dremel maybe.
Have hunted all over t'internet to try and find a similar seal but with a longer skirt, but alas no luck.
piccys here...
https://www.defender2.net/gallery/index.php?cat=10624
Post #13620 30th Jul 2009 4:51pm
Page 3 of 3 <123
