Home > Puma (Tdci) > Puma engine destroyed at 30.000km
Page 2 of 2 <12
MD5
2009 Defender 110 Puma 2.4 SW Alpine White
Who made engine oil testing here in Europe/UK ?
The failure diagnosis of the damaged engine is the following:
A bent valve broke a rocker arm, then the debris fall into the engine damaging one bearing on the cranckshaft.
Post #135804 31st Mar 2012 4:48am
K9F
MD5,
If you Google 'Oil Analysis Services' there are several companies that will carry it out for you. Some you can even post the oil to them. Hope this is what you are looking for. You may be able to find a company closer to home.
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #135833 31st Mar 2012 8:17am
Page 2 of 2 <12
