  • You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Technical > Adjustable tow hitch height
Page 2 of 2 <12
mowcop
United Kingdom 2008 Defender 110 Puma 2.4 CSW Zermatt Silver
I think I will go for an adjustable, will it bolt straight onto what I have or is it a whole new set up?
Post #13527 28th Jul 2009 3:05pm
Grockle
The adjustable should fit the original parts ok. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #13528 28th Jul 2009 3:34pm
110SEB
Rolling with laughter Rolling with laughter Rolling with laughter
Is that forum Tourettes? Sorry about that guys, everytime it tried to submit reply it came back with "fatal error occurred" etc. So i just tried and tried...
Post #13536 28th Jul 2009 5:04pm
mowcop
Spoke to Dixon Bate today, they can sell me a a full set up including all the brackets etc for �142 + vat they said that I need to change the lot due to "type approvel" issues.
I recon I can sell the old one on e-blag or keep it incase I change motors at a later date.
Post #13538 28th Jul 2009 6:09pm
Grockle
Are you sure you need all the bits again,Paul 55 did your swop opposite to you and only needed to swop the drop plate. 2.4 90 XS
Post #13567 29th Jul 2009 7:19am
niglyn
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Stornoway Grey
The DB tow hitch has spreader bars, doublers and reinforcing brackets, so it is best to swap the lot out. It is really quite a simple job. Have a dummy run and bolt it all together before mounting on the vehicle to see how it all goes together. They will sell direct, but look at the aftermarket motor factors, who will sell it cheaper. Use plenty of copper slip, which will make removal easier if required.
There is one change I did. DB want you to drill out the threads on the chasiss, on the fuel tank mounting brakets & fit nuts & bolts. However I left the thread and used a suitable bolt, 12mm I seem to recall. I did aslo put a shake proof & nut on the back as well, just to be sure.
On the new Pumas, they still have this hole but no longer thread it, so I used a 12mm tap and threaded it myself.
My local dealer Harw**ds wanted �325 for the tow hitch and would not budge on price, hence I went to Paddocks. A main dealer to be avoided.
Post #13578 29th Jul 2009 10:24am
mowcop
Now fitted!
Sorry no pics as I was wearing by wellies!
Towed a SWB 140 miles today with no skiding, I can't praise the towing ability of this TDCi it pulls like a train and cruses at 60mph at 2000rpm
25 years later and Land Rover have got it just right.
Post #13990 8th Aug 2009 10:28am
niglyn
Yep, the new puma does tug well. However I doubt they will live 30 years+ like the series did. They now need to sort out all the new issues they have created in the puma model. Sucking water into the fuel, poor build, bad paint, lack of a user repair manual etc, then they will have a winner.
Post #14007 9th Aug 2009 12:00am
Page 2 of 2 <12
