![]() | Home > Puma (Tdci) > Clonk at the rear of my 110 |
CyberCharlie Member Since: 01 Jul 2010 Location: Reading Posts: 140 ![]() ![]() ![]() |
Hi,
If this has been discussed already i apologize but searching for +rear +clonk was not returning anything interesting. So here's the thing: i have a 57 plate 110 Puma. When i move from a standstill i hear a clonk at the rear, then everything is fine. It happens in 1st gear only (apparently) I am pretty sure it has been discussed already but gcouldn't find clues. As i am due for service i wanted to point the mechanic in the right direction. Thanks for your precious help ciao ![]() |
double cab happy Member Since: 01 Jun 2009 Location: merseyside Posts: 573 ![]() ![]() ![]() |
trailing arm bushes (the front large ones) had this affect for me, I also seem to have started a new clonk, which i now believe is the ball joint on the A frame,
hope this helps Mark |
Thanks guys
