Home > Puma (Tdci) > Rattle from Gearbox
CapeLandy
South Africa
Rattle from Gearbox
Just dropped off the Fender at dealers.
While showing the loose breathers etc. we noted the heat shield on the gearbox was completely loose and could be the reason for the rattle sounds. Let's wait and see.
Seems a long shot as the sounds were more mechanical.
 Puma 110 - gone
Series III 1973 - going strong
Post #13483 27th Jul 2009 4:38pm
Grockle
Lets hope they sort it. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #13484 27th Jul 2009 4:54pm
Bosun
That's useful, I have a rattle/resonant sound from underneath. It occurs driving slowly with the engine at about 1300rpm. I'll look tonight. Anywhere else worth looking while I'm grovelling around underneath?
Bosun.
Post #13503 28th Jul 2009 7:22am
CapeLandy
South Africa
check list
Check the following:
Feel on top of your gearbox for the breather hose and make sure they refitted the hard plastic breather pipe that runs to the port side of the engine bay (RH Drive Model).
My breather hose was off and the remaining pipe for the gearbox and rear diff have both chaffed through on something in the engine bay.
Also check the wire loom running next to the gearbox is propery secured with it's white plastic clip.
The heat shield that came loos is on the starboard side at about 1'o clock position between belhosing and engine.
Good luck Puma 110 - gone
Post #13504 28th Jul 2009 8:16am
mse
I had a gear stick rattle and a new selector guide solved it 100% Mike
Post #13532 28th Jul 2009 4:38pm
CapeLandy
South Africa
Got her back again after 1 day in the shop.
Needless to say I am still Censored they never even bothered to drop the oil in the box saying it should be fine.
They have ordered two new breather pipes and refitted the heat shield on the crank sensor on the gearbox bellhousing which aparently caused all the rattle - that I will still have to test.
When LR SA called to see if I was happy I gave them an earful about the oil not being changed or at least checked for contamination.
I told them I am going to another dealer and having it changed at my expence and I will ask them to give me the old oil and I will pay to have it analised.
These people are as usefull as a panty. Evil or Very Mad Puma 110 - gone
Post #13598 29th Jul 2009 9:56pm
CapeLandy
South Africa
Needless to say, the rattle is still there once the vehicle is all warmed up and I also checked the heat shield on the gearbox crank sensor is also still loose. Don't know what they did to "fix" it - maybe some chewing gum.
Can one of you chaps have a look from your engine bay below your exhaust manifold and see if your heat shield is loose and if it is, do you also notice a rattle in 2'nd gear when the revs are a bit low.
Mine is fitted with only one rivit onto a bracket but the fit is totally loose. I am going to see if it's possible to drill out and fit new but it looks a bit cramped down there. Puma 110 - gone
Post #13777 3rd Aug 2009 10:54am
Grockle
Hi CL,sorry to hear your still suffering fools,ours doesn't rattle in 2nd or any gear. 2.4 90 XS
Post #13780 3rd Aug 2009 11:07am
