Home > Td5 > EGR blanking?
RRUK
EGR blanking?
OK, I did a search for this here but found zip.
Can anyone tell me where on the TD5 engine the EGR is located and what it looks like before it's been blanked off and what it might look like after?
I want to figure out if mine's been done.
Thanks
PS: If anyone knows how hard or easy it is that'd be great too! 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #131691 15th Mar 2012 8:24pm
landy andy
Take acoustic cover off engine,
If there is a big sticky out bit with little pipes going to it, on the inlet manifold, where intercooler hose attaches, you still have one.
Easy job to remove Thumbs Up
Andy
Post #131699 15th Mar 2012 8:34pm
landy andy
Post #131700 15th Mar 2012 8:36pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
What it looks like depends on the age of vehicle. As an 03 yours should have the later type with two pneumatic actuators on - earlier ones only had the one. Yours should therefore be blanked in the same way as the instructions above.
Post #131713 15th Mar 2012 8:51pm
Alive Tuning
Here's our Td5 EGR blanking kits - http://www.alivetuning.com/EGR_Bypass.html
You will need an EU3 kit, as you will have the EGR cooler at the front of your engine.
Our EGR kit fitting instructions are available to download here: http://www.alivetuning.com/docs/EGR%20bypass%20kit.pdf
Regards,
Gary.
Post #131731 15th Mar 2012 9:13pm
glyn.c
Re: EGR blanking?
Thanks
can only comment on alive's kit ,just download the idiots guide off their site and its so simple even i can do it Very Happy ! if its not been done de cat and air filter upgrade as well ! the difference is unbelievable ! ALL THE BEST
GLYN
Post #131904 16th Mar 2012 6:21pm
chiefstoker
England 2005 Defender 90 Td5 HT Zambezi Silver
The biggest problem is actually removing the EGR with seized in bolts, good luck Thumbs Up 2005 TD5 90 Hard Top
Beer 'n Sex 'n Chips 'n Gravy
Post #131906 16th Mar 2012 6:27pm
RRUK
Has already been De-cat'd, already got K&N filter, already got silicone hoses. I'd be surprised if the EGR isn't done. Will take a look over the weekend. 2016 D4 HSE
Post #131918 16th Mar 2012 6:51pm
Peter
United Kingdom 2005 Defender 90 Td5 SW Epsom Green
Okay this may be a dumb question but if you de-cat a late td5 and remove EGR will this make the vehicle fail the new 2012 MOT rules that come into force in April ?
Quote:
Exhaust
A catalytic convertor fitted as original equipment but missing will be a reason for failure.
(Source: http://uk.autoblog.com/2012/01/04/changes-...eady/)[/i]
Also mentioned here about post 1992 vehicles de-catted:
http://www.pistonheads.com/gassing/topic.asp?t=1029872
Post #131994 17th Mar 2012 4:26am
chiefstoker
No Peter, not at this stage 'spark ignition engines' only Cool
This was interesting though on the Pistonheads thread:
rds1210 said:
just took the car for mot i checked it over three weeks ago give the underneath a thin coat of waxoyl the vehicle passed the mot but the mot fellow said if the underneath is like that next year he will refuse to mot it Can he do this
I only sprayed a thin coat three weeks ago and because of the weather it as not dry out yet
HAVE OTHERS HAD THIS PROBLEM before
He could have refused to MOT it this year if he thinks it's dirty enough and nothing to do with any changes in January, take it elsewhere next year.
Post #131996 17th Mar 2012 6:26am
Peter
I think its the Waxing issue, MOT'ers tend to dislike the wet stuff or its laid on too thick.
Same goes its its covered in heavy mud I believe.
Post #132025 17th Mar 2012 10:30am
RRUK
Checked mine and it's not been EGR'd yet.
Something for the future. 2016 D4 HSE
Post #133365 22nd Mar 2012 11:00am
Naks
RRUK wrote:
Checked mine and it's not been EGR'd yet. Something for the future.
Do it, and while you're at it, remove the cat and centre silencer box Thumbs Up --
Post #133369 22nd Mar 2012 11:09am
RRUK
They are already done.
People say its an improvement, but what exactly do you notice? 2016 D4 HSE
Post #133374 22nd Mar 2012 11:35am
Naks
RRUK wrote:
They are already done. People say its an improvement, but what exactly do you notice?
When I removed the centre silencer on my D2 Td5, I noticed much quicker turbo spool-up, faster acceleration, and a slight reduction in fuel consumption. --
Post #133376 22nd Mar 2012 11:42am
