Home > Maintenance & Modifications > Roof Consoles - Options and experiences |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
Thought you may have done...
19th Mar 2012 11:50pm |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3639 |
Ibex man
they look great and much more subtle than a peice of plastic (terrafirma) or metal frame (like some others) srewed to to roof added to my wish list all the best Rob DEFENDER 90 TDCI XS, I hope everyone is well and your land rovers make you happy |
20th Mar 2012 6:08am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Me being in lazy mode if you fit will you run the cables if so which route ?
20th Mar 2012 6:51am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
Right hand a pillar
20th Mar 2012 10:46am |
And it looks like there is no need to hack up sun visors as well?
20th Mar 2012 2:03pm |
farmer giles Member Since: 09 Feb 2011 Location: worcestershire Posts: 1299 |
ibexman - now i see why you were interested in the roof vent on my 300 Tdi
if you are interested there maybe scope for me to remove both the inner and outer sections and post them to you for "evaluation" |
21st Mar 2012 10:36am |
Good idea Joe but you will get wet What is the outer section made from???
21st Mar 2012 11:57am |
the 300 is garaged up at the moment. the outer section is a combination of metal and bonded on mdf to make the curved profile.
i will be looking to do a roof vent on my puma when the warranty runs out and it would be great if the inner section was trimmed to match the headlining. i get wet from the sunroof anyway |
21st Mar 2012 12:14pm |
LRSoffroad Member Since: 15 Feb 2012 Location: Doncaster Posts: 189 |
Hello wslr the Cor4 item is wide will take a cb and stereo and is sunk up into the roof lining so your not hitting your head on it , also you dont cut the sunvisors like you do with others
4th Apr 2012 8:51pm |
have you a pic of a cor4 console Derek
4th Apr 2012 9:09pm |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
4th Apr 2012 9:21pm |
tolley Member Since: 07 Nov 2011 Location: gloucester Posts: 1114 |
ibexman what depth are the middle consoles from the roof? and is it possible to make one that fits right across the back that covers half/quarter of the back roof coming from the back door.
5th Apr 2012 1:17pm |
150mm at the rear, as for making an above rear door rear one depends on interest ???
5th Apr 2012 2:45pm |
Mine!!!!
Easy to fit ( less than 2 hours) Need to cut 10 cm the sun guards (I'll do some photos this night) Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition IID Pro MV License |
5th Apr 2012 3:27pm |
