Home > Td5 > Weird drop in power when flat out |
Killer90 Site Sponsor Member Since: 09 Oct 2011 Location: Hertfordshire Posts: 6478 |
hmm, you may be hitting top revs and the ecu might not like that, does it start first time or does it seem like it doesnt want to, also check your injector harness under the rocker cover and the plugs to the ecu for oil
18th Mar 2012 12:00am |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 555 |
might be worth checking the wastegate rod on the turbo then can seize
Will 2005 90 XS 1954 86'' Series 1 tilt 1968 88” 2A 200tdi 2002 110 Hardtop |
18th Mar 2012 12:06am |
amondeggs Member Since: 06 Mar 2011 Location: Telford Posts: 452 |
Thanks killer 90 I will check the plugs in the morning. I'm aware of the oil problem as I had it last summer and fitted a new injector harness then. I would hope that it would not have come back already? Ps sorry we never got anywhere with jack but glad you got a buyer
Thanks derby will, I will check this also. I have never messed with this before but I'm aware that some people do to achieve better performance. I will lube it up in the morning |
18th Mar 2012 12:12am |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10376 |
Injector harness possible, or air flow meter? I've had experience of none genuine air flow meters not liking power upgrades.
Also again as above wastegate rod seizure? |
Laurie Member Since: 22 Feb 2008 Location: Sussex, England Posts: 2897 |
Limiter on a TD5 is set at 89mph.
18th Mar 2012 12:14am |
robpenrose Member Since: 15 Jan 2011 Location: Hampshire or Cornwall Posts: 338 |
Sounds electronic if you can boot it through the gears then it doesn't like full speed.
I have a similar problem. Mine doesn't like full throttle, even for a split second without the engine revving, which sorts itself out after a reset. I suspect possible pedal, but does sound slightly different to yours... Current:D4 HSE Gone: BMW Z4MC Gone: Defender TD5 90 CSW Previous: Discovery TD5 ES (Gone) |
Thanks greeni,
Can you clean the mass air flow sensor? If so how do you do it..? |
Thanks robpenrose,
I did consider the accelerator pedal as I had a driver demand error that lit up the engine management light after a little to much of a soaking at Salisbury a few months ago. I suppose it may be connected? Will look into that |
18th Mar 2012 12:18am |
The car will do this speed but it cuts out well before it gets to this speed |
18th Mar 2012 12:19am |
Mine's gone a bit further than that according to the splat nav |
18th Mar 2012 12:24am |
Mine's gone a bit further than that according to the splat nav [/quote]
Before these gremlins started it would do just about 90, although I would very rarely push it to that. It has the power loss above 70 mph as you accelerating up. After it happens the car will still continue to accelerate but very slowly. Very strange |
18th Mar 2012 12:28am |
no probs regarding the jack and mass air flow youll have to buy another no cleaning it out mate
18th Mar 2012 12:52am |
wslr Member Since: 18 Jul 2010 Location: Wellington, Somerset Posts: 581 |
Your MAF may be maxing out and then putting the ECU into a default setting. You can watch it on Testbook. MAF will jump up past 640kgpa and then it goes off the scale at which point the ECU presumes the MAF has a problem and starts running a basic default. That's the point at which the lack of power starts, and when you back off the power, the ECU sees a good reading again and everything appears normal.
Ask Gary for an uprated MAF sensor. |
18th Mar 2012 1:02am |
Try unplugging the MAF and see if the same problem occurs.. Current:D4 HSE
18th Mar 2012 1:05am |
