Home > Maintenance & Modifications > Stereo help please...
haworthj
I'm wanting to replace the standard Land Rover CD player (with 3.5mm jack) with a Parrot Asteroid.
I've been told I need an adapter. Which one depends on wether the Land rover harness ends with flat pins, or round. Can anyone tell me which it is?
And does anyone have a Parrot Asteroid? I'd love to hear opinions.
James
Post #131038 13th Mar 2012 5:30pm
BigMike
Sounds flippant I know but why not just slip it out and have a look? From memory they are flat but I can't be 100%.
Post #131041 13th Mar 2012 5:43pm
haworthj
I haven't because I don't have the right tools - and my local Halfords haven't got any. Is there something I can make up to slip it out?
Post #131042 13th Mar 2012 5:45pm
BigMike
Post #131045 13th Mar 2012 5:51pm
I wouldn't try a home made way of getting it out been there tried that and failed! Ebay would be good and cheap. you just need a two pronged realease keys. should be very cheap. For memory pins are flat Thumbs Up
Post #131054 13th Mar 2012 6:49pm
haworthj
Thanks Mike. I'll have a rummage around Mrs. H's wardrobe this evening. Laughing
Post #131055 13th Mar 2012 6:49pm
hi haworthj
I had a standard LR (with jack) radio/cd and replaced with CD, nothing required - straight swap
the only thing you have to do is remove little metal flanges on the left and right of the standard radio/cd apature / hole... you'll see what I mean when you take the radio out
make sure you flash the unit... I have my leads all routed through to the dash-top glove box ... no drilling required.
Asteroids - they take a little while to master but are great units Thumbs Up
Post #131071 13th Mar 2012 7:22pm
Glynparry25
The stereo plug on all the Defender are ISO (International Organisation for Standardization). This means it falls in line with all main car stereo manufacturers.
You will find that all major car stereo companies' products will plug straight in.
Glyn Dog Sheep
Post #131082 13th Mar 2012 7:37pm
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Glyn Dog Sheep
Sometimes the +12 accessory and +12v Perm lines are swapped... You'll soon know when you turn the radio off.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #131169 13th Mar 2012 10:38pm
haworthj
If that's the case, what colour wires will I have to swap over?
James
Post #131200 14th Mar 2012 6:42am
haworthj
bpman wrote:
hi haworthj
That looks very smart.
Post #131201 14th Mar 2012 6:42am
K9F
haworthj wrote:
If that's the case, what colour wires will I have to swap over? Cheers James
I too have an Asteroid. 'Plug and play' no wires to swap whatsoever.
http://www.defender2.net/forum/topic7481.html?highlight=asteroid If you go through life with your head in the sand....all people will see is an ar5e!!
Post #131206 14th Mar 2012 7:10am
Shax
James
Not sure what the wire colours will be, but they are A4 and A7 on the plug...
[/img]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #131329 14th Mar 2012 3:56pm
haworthj
Thanks for all your help gents. That's why I love this forum. It arrives tomorrow. Fitting over the weekend.
James
Post #131357 14th Mar 2012 6:45pm
James
Good luck Thumbs Up You'll find it simple enough. Thumbs Up
Post #131359 14th Mar 2012 6:47pm
