Home > Wheels & Tyres > Anyone got pics with 285 or 265/75/16
Page 2 of 2 <12
davew
England 1990 Defender 90 V8 Petrol PU Auto Rioja Red
It's always a good idea to inform your insurance company when fitting oversize tyres, after all you are reducing the braking efficiency of your vehicle so it's the kind of thing that may come up in the event of an accident.
Post #129960 8th Mar 2012 11:58pm
affiliate13
2012 Defender 90 Puma 2.2 HT Sumatra Black
Interesting, i thought having more friction would improve stopping distances.
Perhaps reduce MPG but i didnt imagine it would be less safe.
Post #129969 9th Mar 2012 7:11am
Zagato
Re: Wheels
Peacehill wrote:
This is my 90 from last year. 285 BFG KM2's. On standard Boost's, standard 90 CSW suspension, no spacers.
[/img]
_________________
Mark
2011 110 XS DC
Stornoway Grey
Have you had any trouble with rubbing/turning circle etc. also what is it like for mud up the side of you vehicle. Got a new black defender coming and this looks the business. Just not sure how practicle for everyday farm use
Thanks
Ross
Pic hasn't come up Ross Sad
Great thread also interested to know about rubbing etc Thumbs Up
Post #129972 9th Mar 2012 7:48am
davew
It's often overlooked, it's not the friction between the tyre and the road but the effectiveness of the brakes themselves. If you think of the radius of the tyre as a lever pivoting around the centre of the hub, the bigger the radius the longer the lever so the more rotational force exerted at any given speed. So to create the same braking force on a bigger radius tyre at the edge of the tyre takes more effort at the brake rotor which is much nearer the centre of the wheel.
Bigger tyres = slower acceleration + reduced brake efficiency + lower engine revs at a given speed
Post #129979 9th Mar 2012 8:07am
ay4alex
United Kingdom 2008 Defender 110 Puma 2.4 XS DCPU Java Black
Re: Wheels
Ross, If you adjust the steering stops, you can get a better turning circle, regarding mud up the side of the car, we made some small plates that fix to the bottom of the wheel arch and the top of the mudflap, you can see here that they aren't really visible and do actually stop quite a bit of mud!
IMG_0128 by .:ay4alex:., on Flickr
IMG_0124 by .:ay4alex:., on Flickr
IMG_0122 by .:ay4alex:., on Flickr
and this is with 285 All Terrains, 30mm spacers too.
IMG_0137 by .:ay4alex:., on Flickr 110 Tdci Double Cab
Post #129983 9th Mar 2012 8:32am
The Boy
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Rimini Red
285's on 16 x 8.5 inch rims
I have them delcared on my insurance as I have a agreed value. They may be (stil can't quite make up my mind) up for sale soon as I am thinking of going onto 255's on the boost. The sale of these should help towards the cost.
Post #129985 9th Mar 2012 8:40am
Cibit
Hi Boy hows things? Say hi to your brother for me.
Oh and that truck of yours is stunning mate Thumbs Up outstanding job Cool
So is Ay4alex too some lovely looking landies about Mr. Green 59 2.4 110 XS Utility
55 TD5 110 CSW Special Vehicle
Post #129998 9th Mar 2012 9:56am
The Boy
High praise indeed thank you. Was thinking of getting rid of it and replacing it with a DCPU but keeping it now. still have soem bits to bolt on yet like the new exhaust Laughing
Will let Chris know you said "hi".
Boy
Post #130001 9th Mar 2012 10:09am
landy4x4xfar
Falkland Islands 1999 Defender 110 Td5 USW Alpine White
and a set of Goodyear 285/75/16 MT/R now they are hard to find
Post #137051 4th Apr 2012 10:32pm
twopoint6khz
United Kingdom 2005 Defender 110 Td5 CSW Java Black
That's a common misconception, but as long as your brakes can generate enough torque to lock the wheels (which is true of most modern vehicles) then that is NOT the case. It may depend how you define efficiency, but the stopping distance would remain the same.
Yes you will require more braking force to produce the same retarding torque at the ground, but if you can lock the wheels then force is not the issue - traction is. Therefore larger tyres may actually brake better due to the larger contact patch. However things such as the increased moment of inertia probably cancel this out.
Confusion can arise because larger wheels will make your car accelerate slower. This is because, unless you drive a dragster (or you're Killer90), there's not enough engine torque to spin the wheels in every gear.
Post #137085 5th Apr 2012 8:17am
defender4
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Java Black
Another potentially limiting factor to bear in mind when fitting wider tyres, is the clearance to any undershield that you may have fitted. While the back edge of the tyre may clear the steering stops (which you can adjust) the front edge may foul a steering guard (which you can't adjust so easily).
Post #137096 5th Apr 2012 9:15am
The Boy
Not a problem with mine Thumbs Up
Post #137119 5th Apr 2012 11:11am
pom
Allways thought the white lettering displayed on the outside of the wheels looks a bit camp.
Pom
Post #137156 5th Apr 2012 1:02pm
twopoint6khz
Camp? That's a new one Rolling with laughter
Lettering inside/outside? You might as well ask "do you like Marmite?".
Post #137185 5th Apr 2012 2:33pm
landy4x4xfar
as for the white Lettering the tyres are over 5 years old and still going strong Bow down Thumbs Up
Post #137260 5th Apr 2012 7:35pm
Page 2 of 2 <12
