Home > Technical > Pioneer radio losing settings |
XS Pete Member Since: 13 Jan 2011 Location: Suffolk Posts: 632 |
Are you sure that the permanent and ignition switched lives aren't swapped. I can't remember which manufacturer it was but one of them had a habit of doing this a while back.
Pete |
28th Feb 2012 11:45am |
scotty38 Member Since: 21 May 2011 Location: Lincolnshire Posts: 571 |
Pretty sure they're ok and connected the right way. I've tested both with a meter and also swapped them for a test and then as expected the unit loses its settings every time the ignition is turned off.
28th Feb 2012 12:37pm |
That's a bit odd. Pioneer stuff is usually pretty good. I can't see you'd get two dodgy ones in succession (although I suppose it's not beyond the realms of possibility).
Maybe someone has swapped connections in the LR loom to accommodate a previous radio. Someone (DGardel I think) posted a connection diagram for the pin outs for the dash connectors. Have a look in his gallery. Probably worth checking it's as it should be as a starting point. Pete |
29th Feb 2012 1:01pm |
warren Member Since: 14 Oct 2009 Location: East Lancs. Posts: 903 |
I have a Pioneer stereo that does exactly the same thing... At first I thought it was just because I'd left the ignition on for a couple of hours to listen to it whilst working outside, and it just ran the battery down a bit. But it's done it a few times when I've just been parked up for five minutes.
Chappy at Halfrauds got his testing kit on the wiring and reckoned it was because the voltage on the permanent feed dropped below 12v when starting, and that was causing it to default back to factory settings. Not sure how true this is as the original Land Rover one never lost it's settings. Is yours like this by any chance? Click image to enlarge |
29th Feb 2012 7:13pm |
It was a brand new car to me so should be ok but thanks for the thought.... |
29th Feb 2012 9:55pm |
Mine is exactly like that and does happen after the initial ignition and the delay for waiting for the glow plugs so that makes sense although as you say the OE radio copes ok although it does "switch off" momentarily. Maybe the original radio is just less susceptible to a lower voltage than the Pioneer? |
29th Feb 2012 9:58pm |
That's bizarre. It sounds as though the radio doesn't have enough internal 'hold up' or 'ride over' time engineered in to be able to survive during 'brown out' conditions. Most sets usually have some large capacitors (or in some cases a tiny battery) built in to hold enough charge to be able to retain settings during these conditions. Some sets you can actually disconnect for a few minutes before they revert to the factory defaults.
I suppose you could connect a largish electrolytic cap in the loom as close to the back of the set as possible, but this is going to make the install a bit tricky as there isn't much room back there when the radio is in position. Another alternative theory could be that the OEM permanent live is very small diameter cable (I can't actually remember for sure) which would make the voltage drop issue worse. Fixing that would involve running a replacement permanent live via the shortest route possible in larger diameter cable directly to the battery. Either method seems a lot of effort to go for something which should have been engineered in. Afterall, most vehicles suffer from these condtions during cranking. Pete |
1st Mar 2012 9:30am |
Yes, I would have to agree with all of that so it would appear that my only (viable) option is to try and get it swapped out for another make once it's been "repaired" and still doesn't work...... |
1st Mar 2012 9:39am |
